Throttle a little sticky
Postby Chilli » Tue Aug 11, 2015 7:53 pm
Hi guys
As mentioned my throttle is a little sticky on changing gear,it doesn't seem to want to ease off on the change over,any advice ? :idea:
Chilli
Re: Throttle a little sticky
Postby Toddy » Tue Aug 11, 2015 8:15 pm
Do you mean not returning properly or sticking at the carb end a few ideas , Fraying cable ? Stiff throttle rod ? Light switch cable tight against rod ? Cable routing ?
Postby Chilli » Tue Aug 11, 2015 8:36 pm
Hi Toddy
Yes sorry not returning properly,it's not sticking at the carb end and the cable isn't frayed,it feels it's on the actual throttle grip
Chilli
Postby Toddy » Tue Aug 11, 2015 9:27 pm
Chilli wrote:Hi Toddy
Take it off and have a look may be slack under the grip take the headset top of and have a look inside
