MickYork wrote:132 seems a bit big, try coming down to 120 and see how it performs........keep checking the plug though
Rich Oswald wrote:Just my opinion but your main and pilots look too big. I would think about 120 main and 50 pilot would be about right for a st'd 200,
Granty wrote:Troops -- eventually got the carb set up & ready to go for real, the last bit of advice sounds a bit dumb but I've only ever had smaller carbs running through the box, I now have a opportunity to try out a 20mm open mouth carb -- quick question.................... is there any difference in driving an 30mm open mouth throttle wise then a 26mm through the box, particularly on using the throttle ie gradual opening up etc?
Cheers Troops - G
132 main jet
AV264 atomiser
X7 needle with clip 2nd top
55 pilot
70 choke
40 slide
Rich Oswald wrote:Granty wrote:Troops -- eventually got the carb set up & ready to go for real, the last bit of advice sounds a bit dumb but I've only ever had smaller carbs running through the box, I now have a opportunity to try out a 20mm open mouth carb -- quick question.................... is there any difference in driving an 30mm open mouth throttle wise then a 26mm through the box, particularly on using the throttle ie gradual opening up etc?
Cheers Troops - G
I would say no to this question unless of course you have a highly tuned kit like a TS1 or RB etc where the power band can kick in quite soon in the throttle opening.
Users browsing this forum: Bing [Bot] and 39 guests
