by jonoy » Mon Aug 03, 2015 8:09 am
I am changing to tubless rims
If I fit the wider rear is it straight fit
or does anything need modifying
jonoy
by Digger » Mon Aug 03, 2015 11:58 am
Wider rear?
Digger
by Warkton Tornado No.1 » Mon Aug 03, 2015 1:34 pm
Presumably you mean a wider rear (tubeless) rim to suit the use of different aspect ratio tyres. It's probably a good change based on the tyre choice/availability alone!
No doubt you're aware that this will also effect overall gearing.
There may have been discussions on this Forum, but all that I know is that 110/90 x 10 may rub on the 'inner' crankcase face as may 4.00 x 10 on the bump stop.
by monument7 » Mon Aug 03, 2015 1:42 pm
How can it affect the gearing when the rolling diameter is the same ?. Just asking lyke
monument7
by Bristol Daz » Mon Aug 03, 2015 3:20 pm
The rolling radius of the wheel will be the same, but if a different size tyre is used the overall rolling radius may change and alter the final gear ratio.
Bristol Daz
by jonoy » Mon Aug 03, 2015 4:57 pm
Thanks for. The replies
I will just put same standard size front and rear
jonoy
by Warkton Tornado No.1 » Mon Aug 03, 2015 6:17 pm
Sorry!
I didn't mean to put you off, & in racing, the specials classes have used wider rubber on the back for years.
However, you have the consolation of precise interchangeability, front to back.
by jonoy » Mon Aug 03, 2015 7:51 pm
It's ok
I've ordered a pair of wheels .
Then I started thinking about the wider rear. Would it make sense to go wider rear as I can still change the order .
jonoy
by ian i.o.w » Mon Aug 03, 2015 9:53 pm
wider on back for me more rubber on the road need to use a spacer to keep away from crankcase
ian i.o.w
by hullygully » Tue Aug 04, 2015 1:50 pm
if you keep the alloys/steels the same but place the larger tyre on the rear then there's no mods @ all except for the stud replacement if using SIP
by jonoy » Tue Aug 04, 2015 3:26 pm
Not Sip, Af Rayspeed
jonoy
by hullygully » Wed Aug 05, 2015 10:10 am
no mods then buddy
by Fish » Wed Aug 05, 2015 12:11 pm
You will need longer studs on both hubs if using AF tubeless rims, on wide or standard
Fish
by Rich Oswald » Wed Aug 05, 2015 12:15 pm
Fish wrote:You will need longer studs on both hubs if using AF tubeless rims, on wide or standard
Not correct for standard width. No stud mods req.
by jonoy » Wed Aug 05, 2015 9:15 pm
Got my rims and tyres today
Supplied with tall dome nuts and 2 different washers
Cannot get the front on not enough thread
jonoy
by Fish » Thu Aug 06, 2015 12:32 pm
Rich Oswald wrote:Fish wrote:You will need longer studs on both hubs if using AF tubeless rims, on wide or standard
jonoy wrote:Got my rims and tyres today
Thats why I posted my comment - I had the same issue, change studs to longer and all good
Fish
by jonoy » Thu Aug 06, 2015 3:17 pm
I may order a wider rear then I will have a standard rim as a spare.
Does the 350.10 tyre go on ok or do you put a different tyre on
jonoy
by bike grim » Thu Aug 06, 2015 4:02 pm
My AF Rims fit fine on standard studs, had them a couple of years have they changed something?
by jonoy » Thu Aug 06, 2015 4:25 pm
Don't know I have the rear on but the front once the wave washer and split washer are on no thread for dome nut to grip
jonoy
by jonoy » Thu Aug 06, 2015 6:33 pm
One scratched to f--k font Rim what a waste of money
jonoy
