Torque Wrench
Torque Wrench
Postby Lambr62 » Thu Jul 30, 2015 3:59 pm
Hi There,
Not a scooter related question as such, but wondered if anyone can recommend a torque wrench that can be used for both RH & LH Threads. My current one only works in the RH direction. Thanks in advance.
Lambr62
Re: Torque Wrench
Postby HxPaul » Thu Jul 30, 2015 4:28 pm
I use a beam type torque wrench,but it doesn't click when you reach the correct torque,you have to watch the guage,this works in both directions.
Re: Torque Wrench
Postby St George » Thu Jul 30, 2015 5:54 pm
I have a Norbar torque wrench which allows the socket to be reversed. It is quite old but they may still make them.
St George
Re: Torque Wrench
Postby Wack » Thu Jul 30, 2015 5:56 pm
Mines a Teng 1/2 inch drive
Re: Torque Wrench
Postby ian i.o.w » Thu Jul 30, 2015 10:08 pm
I have two from Halfords found them good :D
ian i.o.w
Re: Torque Wrench
Postby Captain Pugwash » Thu Jul 30, 2015 10:47 pm
ian i.o.w wrote:I have two from Halfords found them good :D
Halfords own brand do seem to get a good write up. http://www.autoexpress.co.uk/accessorie ... group-test
I believe they are manufactured by NorBar.
Captain Pugwash
Re: Torque Wrench
Postby Tractorman » Fri Jul 31, 2015 8:57 am
I used a Sealey 3/8ins drive 0-18ftilbs that will do the lower torques and a britool 1/2ins drive with a knock through head for the rest. You need to be sure if you get a ratchet one that it doe actually torque l/h threads, not all do.
Re: Torque Wrench
Postby CHRIS in MARGATE » Fri Jul 31, 2015 9:01 am
Britool 1/2 inch with knock through. Only drawback is it starts at 20 ft lbs so have to knock it back beyond the first calibrated lines to get my 16 -18 for cylinder head. Had it since the ark.
Re: Torque Wrench
Postby mark1 » Fri Jul 31, 2015 5:18 pm
Halfords tools are excellent. I've used their torque wrench for 6 or 7 years now without any concerns.
mark1
Re: Torque Wrench
Postby Simon ELC » Tue Aug 04, 2015 9:10 pm
As the Captain and Mark1 have stated Halfords torque wrenches are excellent and they have a lifetime guarantee.
Simon ELC
Re: Torque Wrench
Postby bigbthesoulman » Tue Aug 11, 2015 10:22 am
I bought one from lidl,crackling piece off it kit for money
bigbthesoulman
