fitting front dampers to my gp150
Postby kennystag » Thu Jul 16, 2015 9:44 pm
Hi All
I am fitting escort shockers to my GP150. Can anybody tell me what the distance between the 2 bolt holes on the shocker should be to fit to the forks
Stag
kennystag
Re: fitting front dampers to my gp150
Postby CambTim » Fri Jul 17, 2015 5:07 pm
have a look at Camb Lams site on welding brackets for dampeners. They tell you where to weld them on distance etc.
CambTim
Postby Norrie Bodge » Fri Jul 17, 2015 8:17 pm
Norrie Bodge
Postby kennystag » Wed Jul 22, 2015 5:13 pm
Hi thanks,
Is it 10 inches from the top eye bolt hole to the bottom eyes bolt hole on the shocker, can anybody help with this, I am using Escort shockers
Stags
kennystag
Postby HxPaul » Wed Jul 22, 2015 7:53 pm
The top mount should be welded/bolted in the case of bolt on brackets, just below the fork stop indentation.If the fork link is at its lowest point and the shocker fully extended,then the top bracket should be attached 10mm lower than the fullest extent of the shocker, which gives the shocker enough travel.
