S2 outboard disc brake
Postby Jeff t » Tue Jul 07, 2015 10:54 am
Hi I'm fitting a scoots rs disc brake to a S2 and routing the hose up the forks but can't get the hose past the headset clamp. I've removed the banjo's and it looks like the hose body itself would be ok its just the nut that the banjo attaches to. Only options I can see is to remove the headset clamp and route the hose then re-build the headset. Anyone come across this before and any ideas.
Cheetrs
Jeff t
Re: S2 outboard disc brake
Postby Donnie » Tue Jul 07, 2015 11:00 am
Are you using the rubber hose that usually comes with these?
Personally when I did mine I dumped it and built my own hose, that way it was just a matter of threading the hose then attaching the banjos I wanted to use at either end.
Donnie
Postby Jeff t » Tue Jul 07, 2015 11:11 am
Hi no its a Venhill hose, ive removed the banjo's but still can't get the nut past, I assumed the nut the banjo fits too is crimped to the hose.
Jeff t
Postby Donnie » Tue Jul 07, 2015 11:31 am
Ah, I don't know then Im afraid, I didn't use a venhill, i used a kit I made up off a reel of stainless braided hose.
Hmm you may well have to loosen off the headset clamp to get it through then, unless anyone else has used that hose and found another way?
Hope you get it sorted though mate, it'll be worth it in the end. :D
Donnie
Postby Jeff t » Tue Jul 07, 2015 11:52 am
Ok thanks mate looks that way to me just mking sure I wasn't missing the obvious.
Jeff t
Postby Toddy » Tue Jul 07, 2015 12:27 pm
Yeah loosen the headset clamp as said above , feed through the hose its fine, its getting the end fittings through is the issue :D
Postby Jeff t » Tue Jul 07, 2015 2:23 pm
thanks all sorted... :D
Jeff t
Postby Bluenose1 » Mon Aug 22, 2016 9:05 am
Hi Chap...how did you route it through, and around the headset ? Had to virtually double mine back to and around the throttle whell, then down past the clamp... wondering what routing you took ? Cheers
Bluenose1
Postby ian i.o.w » Mon Aug 22, 2016 5:22 pm
Hi Jeff t were did you get series 2 disc brake from and did it come with series 2 switch housing cheers Ian
ian i.o.w
Postby burnside » Mon Aug 22, 2016 8:50 pm
ian i.o.w wrote:Hi Jeff t were did you get series 2 disc brake from and did it come with series 2 switch housing cheers Ian
I got one a couple months back from Buzz Solomoto, he's out of stock of the anti-dive version but seems to have the standard versions in stock, you just specify which switch housing you want on checkout...
http://www.buzzsolomoto.co.uk/scooters-parts.php/dept/disc-brakes/cat/LAM-003-155/id/003751
http://www.buzzsolomoto.co.uk/scooters-parts.php/dept/disc-brakes/cat/LAM-003-155/id/004040
burnside
Postby Jeff t » Tue Aug 23, 2016 10:53 pm
Hi pretty certain i got it from just lambretta and came complete, I routed mine through the hole for the headset clamp bolt and down the horn casting hope that helps cheers.
Jeff t
Postby ian i.o.w » Wed Aug 24, 2016 8:55 am
Thanks for replies
ian i.o.w
