headlight rim
headlight rim
Postby gizmo » Tue Jun 23, 2015 9:20 am
same old story. i have often had bad fitting rims on a gp but have just got one for a sx headset and the fit is terrible and not so easy to file out inside. anybody found a decent fit one anywhere
gizmo
Re: headlight rim
Postby JETEX » Thu Jun 25, 2015 1:07 am
I bought a Casa SX type headlight rim thinking it would be a good fit, but it's awful. I filed it when I dry built the scoot, but I'm dreading fitting it now that the headset has been painted.
JETEX
Re: headlight rim
Postby Jazzy b » Thu Jun 25, 2015 5:16 am
i bought an original old one and had it rechromed you no it will fit then
Jazzy b
Re: headlight rim
Postby gizmo » Thu Jun 25, 2015 7:37 am
Jazzy b wrote:i bought an original old one and had it rechromed you no it will fit then
That's probably best idea, you don't have a spare one hidden under your bed by any chance :-)
gizmo
Re: headlight rim
Postby Jazzy b » Thu Jun 25, 2015 1:25 pm
To be fair I did av a couple gave one away on here will av a look
Jazzy b
Re: headlight rim
Postby burnside » Fri Jun 26, 2015 3:03 pm
I bought a Casa one from CamLam a few years back that fitted just fine
burnside
Re: headlight rim
Postby gizmo » Fri Jun 26, 2015 4:41 pm
burnside wrote:I bought a Casa one from CamLam a few years back that fitted just fine
Blooming mystery these rims. The casa one I got is even slightly out of shape to the headset and would need at least a couple of mil off all the way round the inside as well. The headset is an innocenti one and top and bottom fit well.
gizmo
Re: headlight rim
Postby Cgt75b » Sun Jun 28, 2015 6:57 pm
Is it the one with the adjuster hole at the bottom ?
Re: headlight rim
Postby gizmo » Sun Jun 28, 2015 8:24 pm
Cgt75b wrote:Is it the one with the adjuster hole at the bottom ?
Yes has the piece at bottom for headlight adjuster screw
gizmo
Re: headlight rim
Postby Mori63 » Mon Jun 29, 2015 1:18 pm
I bought a Casa one a couple of years ago and it fitted lovely on the top half and only 3or 4 mm out at the bottom........shame
Mori63
Re: headlight rim
Postby Dimitrios_231 » Mon Jun 29, 2015 7:55 pm
I tried a new Casa here,
no way.
I must clean and polish an original one.
Dimitrios_231
Re: headlight rim
Postby gizmo » Mon Jun 29, 2015 8:58 pm
Dimitrios_231 wrote:I tried a new Casa here,
no way.
Exactly same issues and the top of the rim was a slightly different shape to the headset too, I shall be on the hunt for an original one even if I have to have it re chromed
gizmo
Re: headlight rim
Postby burnside » Mon Jun 29, 2015 9:23 pm
Maybe mine wasn't Casa after all then, it was a few years ago. But it was from CamLam so maybe worth giving there's a go?
http://www.lambretta.co.uk/shop/headlight-listvsx-p-1255.html
burnside
Re: headlight rim
Postby Dimitrios_231 » Tue Jun 30, 2015 9:16 pm
I'll fit the original rim,it needs some TLC but it fits.
With the Casa rim I can only fit the 3 out of the 4 screws,not bad it could had been worse :mrgreen:
The original
Dimitrios_231
Re: headlight rim
Postby Dimitrios_231 » Wed Jul 01, 2015 7:48 pm
burnside wrote:Maybe mine wasn't Casa after all then, it was a few years ago. But it was from CamLam so maybe worth giving there's a go?
This made me think that there is also another Italian brand that makes octagonal rims,the Bossata.
Luckily,my local dealer had one in stock,
I tried it and it fits,
it is not a 10/10 but it is highly acceptable.
Bosatta,original,Casa
Bosatta,Casa
Progress...
Dimitrios_231
Re: headlight rim
Postby gizmo » Wed Jul 01, 2015 8:52 pm
I might give one of them a go, I have seen them complete with headlight which I also need but they are the plastic type not glass. Lovely looking bike by the way
gizmo
Re: headlight rim
Postby Dimitrios_231 » Wed Jul 01, 2015 9:10 pm
Cheers,
it is a friend's scooter that I'm working on the last months,
I forgot this Bosatta pic,
initially it doesn't look very good but it has great potential,bear on mind that the screws are not fully in and I haven't removed any paint.
I've also found an original one that fits like a glove but these are quite rare/expensive nowadays.
Dimitrios_231
Re: headlight rim
Postby Cgt75b » Fri Jul 03, 2015 8:46 am
Apologies for the late reply, the one I have doesn't have the adjuster at the bottom.
Good luck with your search.
Re: headlight rim
Postby gizmo » Thu Jul 09, 2015 6:03 pm
Found an original rim, far better but still needs a tadge off to allow for paint
gizmo
Re: headlight rim
Postby Dimitrios_231 » Thu Jul 09, 2015 8:40 pm
Nice,to be honest,a good original is always superior.
I used the Bosatta as the scooter is not mine :)
Dimitrios_231
Users browsing this forum: No registered users and 120 guests
