Swallowed reed petal
Postby Psychedelicropcircle » Sun Jun 28, 2015 11:28 am
This is wots left of a reed petal, I'm trying to strip the barrel off which seems to be stuck on the pins. I wanted to strip it to make sure none of the petal got pushed into the ports which I can see hasn't. That leaves the crank area unchecked. Question is will it just get pulped?
Re: Swallowed reed petal
Postby Psychedelicropcircle » Sun Jun 28, 2015 7:52 pm
Obliterated then melted onto piston crown and cylinder head. Some wet & dry / time! ;) sorted
