Mikuni TMX35 advise
Mikuni TMX35 advise
Postby cobby56 » Wed Jun 24, 2015 4:35 pm
Recently built a TS with a Mikuni TMX35, seems ok so far done around 300 miles. Spluttered to a halt today, thankfully on my drive, petrol spewing out overflow on front of float bowl. Presuming float issue. Took float bowl off but cant see anything obvious. Anyone suffered similar or got any ideas. Possibly re set float height, if so how ?? Never had one of these carbs before so its a learning curve. Thanks in advance for any thoughts
cobby56
Re: Mikuni TMX35 advise
Postby nastro azzurro » Wed Jun 24, 2015 5:04 pm
I've had this. Carb was about 6 years old at the time. Changed float and been ok since.( 18 months ago )
Is it an old carb?
nastro azzurro
Postby cobby56 » Thu Jun 25, 2015 9:26 am
Brand new, going to have a good look today, but cant understand why its suddenly happened
cobby56
Postby amb » Thu Jun 25, 2015 3:44 pm
Just a suggestion but i had a problem with my tmx35 a while ago ,petrol pissing out and eventually found that there is a small clip that is attached to the float valve needle and it connects the needle to the float arm , said clip kept comeing away from the valve and stopped it closeing ,tightened the clip onto the needle and it cured the problem ,hope this makes sense .
amb
Postby cobby56 » Thu Jun 25, 2015 5:05 pm
It does make sense, thanks for that I'll have a look
cobby56
Postby Toddy » Fri Jun 26, 2015 6:01 pm
Did you get sorted Cobby?
Postby cobby56 » Fri Jun 26, 2015 10:26 pm
Seem to have sorted it, clip mentioned was slack,also noted float height was possibly wrong but not sure about this at the moment, as you know I've built loads of motors over the years but never had one so bloody jinxed
cobby56
Postby hullygully » Mon Jun 29, 2015 10:28 am
once you've set it up bruv you'll find the economy & throttle response to your liking 8-)
Return to Carburettors
