LI125 S3 Reving up!
LI125 S3 Reving up!
Postby rodders » Tue Jun 23, 2015 10:19 pm
HI, when my scooter gets hot and I come to a stop, it starts reving it's self up. The revs then die off a bit when I put it in first and let the clutch out a bit, just so it gets the bite. The cable seems fine and it is new. Anybody have any ideas as to what it could be? Could it be the clutch?
Thanks for your time, guys.
rodders
Re: LI125 S3 Reving up!
Postby johnnyXS » Tue Jun 23, 2015 10:38 pm
typical symptoms of a weak idle mixture caused by an .........Air Leak somewhere on the Inlet.
If it was running ok before and its just suddenly happened I'd check the manifold to engine gasket and the carb to manifold joint for leaks.
Check the carb over and make sure the air screw hasn't fallen out ;)
If you still find nothing you will probably need to do a crankcase pressure test
Remove carb and seal off the intake manifold
Seal off the exhaust port
Attach an air fitting that lets you pressurize the motor (usually through the inlet plug or the spark plug hole
Pressurize the motor to 6-9 psi via a hose that has a pressure gauge. (floor Bicycle pump would do)
check gauge for 5+ minutes to confirm there is no loss of air pressure.
If your gauge shows a leak, spray the gasket seams and seals on the pressurized motor with WD-40. The WD40 will make visible bubbles, and a leaking sound, when you spray the leak point.
johnnyXS
Postby CHRIS in MARGATE » Tue Jun 23, 2015 10:47 pm
Do this sooner rather than later or you will cause serious damage such as holing a piston due to rapid overheating.
Postby rodders » Tue Jun 23, 2015 10:53 pm
Cheers gents. I'll get on the case. Problems are never ending haha
rodders
Postby missing lynx » Wed Jun 24, 2015 5:29 pm
what type of carb have you got?
Postby rodders » Wed Jun 24, 2015 6:59 pm
It's a Dellorto SH120 I think . Should the carb have a deal where it clamps to the manifold?
rodders
Postby CHRIS in MARGATE » Wed Jun 24, 2015 7:02 pm
"Deal" ..... explain. Is that a typo?
Postby rodders » Wed Jun 24, 2015 7:17 pm
Yeah, sorry. It should have said seal*
rodders
Postby 911hillclimber » Wed Jun 24, 2015 8:33 pm
Yes it should, just replaced mine.
Old one was hard to get out and the carb body is very weak so take great care.
The clamp is not much better...
New seal came from Scoot Restorations.
911hillclimber
Postby rodders » Wed Jun 24, 2015 9:29 pm
Brilliant! Thanks for that. Hopefully that will solve the problem. I'll let you know.
rodders
Postby Matty73 » Fri Jun 26, 2015 9:40 pm
Hi, not sure if you've sorted this but mine was doing something similar. Found to to be the throttle cable (carb end) on a phbh, re housed it and it's now fine. Really simple oversight on my part, it was doing my nut in until I'd sussed it.
Hope it's something as simple.
Matty73
Postby rodders » Wed Jul 22, 2015 9:02 pm
just to let you know, I sorted the problem. I changed the car-manifold reduction sleeve (and you were right, it was a bitch to do) to only find when I put it back together that there was a split in the air inlet hose. Changed that, and it is now fine. Thanks for all of your help, it's very much appreciated.
rodders
Users browsing this forum: Google [Bot] and 57 guests
