by mark_mc » Fri Jun 19, 2015 9:13 pm
Hi All,
I'm trying to repair a GP horncast and i need to know the correct size of ''taps'' required and the correct size of holes to drill for the ''taps''
Its 1 of the 4 main screws that connects the horncast to the leg shields and the 2 small ones that connect the front mudguard to the horncast.
Thank you for your help
mark_mc
by Wack » Sat Jun 20, 2015 8:50 am
They're all M5x0.8 mm and you usually use a 4.2 mm drill bit
by mark_mc » Sun Jun 21, 2015 9:47 pm
Thank you for the replies, i have ordered a couple of drill bits and a new M5 x 0.8 tap.
mark_mc
