Float jet
Float jet
Postby jonno » Sat Jun 20, 2015 8:37 pm
Would too big a float jet cause any problems setting up a carb. Got lumpy power to about 3/4 throttle ,but it feels hard,struggling to accelerate.Got a 300 in a 30 mm dellorto (is this standard cant remember) on a mugello 225 with jl3 pipe. Its fitted with an lth reed valve and i only increased the main jet and had to fit a sweet breath filter last time Ifitted this carb.I did replace it with a 26 mm dellorto but that couldnt cope too well.
jonno
Re: Float jet
Postby Rich Oswald » Sat Jun 20, 2015 10:33 pm
300 float valve should be fine and not cause anysetting up problems. In fact it's a necessity really (200 being factory standard).
Re: Float jet
Postby hullygully » Sun Jun 21, 2015 10:52 am
you haven't told us what your needle & atomisor are? or your pilot? :roll:
Re: Float jet
Postby jonno » Sun Jun 21, 2015 8:09 pm
55 pilot av266 atomiser x7 needle. Ive had tis carb and set up on the scooter before ,and no problem till holed piston.Got replacement piston through dealer,not been the same.Could it be the piston? Think it was Avanti .
jonno
Re: Float jet
Postby tommar » Sun Jun 21, 2015 9:38 pm
Holed piston, Lean,?????. :roll:
tommar
Re: Float jet
Postby rossclark » Sun Jun 21, 2015 11:54 pm
What clip is the X7 on?
Re: Float jet
Postby jonno » Mon Jun 22, 2015 4:57 pm
The holed piston was an air leak as had been running for a couple of years all well and good.It took off like a rocket, i knocked it off ,but too late.The clip is second from bottom so on the richer side.
jonno
Re: Float jet
Postby rossclark » Mon Jun 22, 2015 11:23 pm
Be worth a try to have it on the second top with the half shim.
Re: Float jet
Postby jonno » Wed Jun 24, 2015 5:51 pm
Ive taken out the main jet to check the atomiser needle,which should be ok as its what I've used before.See what you think.Runs up to 3/4 throttle then four strokes above that which is the info I took from some carb set up info I have
jonno
Re: Float jet
Postby Mr G in NYC » Wed Jun 24, 2015 6:37 pm
check that there is no fuel in the float, I've had two brand new carbs
with dodgy floats :shock: G
Users browsing this forum: Google [Bot] and 65 guests
