rossclark wrote:So that would have affected it at low throttle opening till just when it came on the taper? Up to about a 1/3 throttle?
Was the rest of the taper right?
mark1 wrote:Adam_Winstone wrote:FYI - My Avanti TT3 top end didn't miss a beat during my 900 miles in 4 days of getting to Mannheim (Germany) before I decided to call it a day and return home (450 there and 450 back). We spent a number of hours at 70+ on motorways, holding that speed as a constant cruising speed with plenty left for overtaking.
I ended up wimping out after shearing a layshaft and hub, which I replaced for the return leg, but it was nice to have absolute confidence in the top end. I only had the plug out once to check colour and it was a glorious chocolate brown
Great kit!
Adam
I agree with everything you've said about the kit Adam. Unfortunately I hole'd the piston in mine on the way to ebensee. I didn't even make it out of the country.
I tried everything possible to get it set up right for the trip, dyno, loads of high speed motorway miles, cht gauge, check, check check. Unfortunately it hole'd at 65mph doing 5,900 revs (I've done over a dozen runs of 10 miles at 7,000 revs, 77mph with no problems what so ever)
Ah well, new piston and barrel re-line then I can start again.
Fat Trucker wrote:mark1 wrote:Adam_Winstone wrote:FYI - My Avanti TT3 top end didn't miss a beat during my 900 miles in 4 days of getting to Mannheim (Germany) before I decided to call it a day and return home (450 there and 450 back). We spent a number of hours at 70+ on motorways, holding that speed as a constant cruising speed with plenty left for overtaking.
Great kit!
Adam
Mark what exhaust are you using?
Blaginit wrote:Hi Mark1 what timing btdc were u set at when you holed piston or are you variatronic cheers for any help
Blaginit wrote:Hi mark maybe I've miss read but I thought timing for these kits is 17 degrees static that's it or they just run to hot and you loose your 30% heat reduction ?im not sure as anyone got any paperwork I'm still waiting for my kit.
Jamjo wrote:Another great thread to follow , keep up the good work Mark
