johnnyXS wrote:that plug doesn't look good to me at all.
I would say that the mixture was ok at some point because there is a nice biscuit colour to the electrode ceramic ,...but .......something has changed since that time .
There is a heavy coating of carbon and oil which could suggest that you have either got the oil /petrol ratio wrong last fill up or you've lost an oil seal somewhere. That could cause a signifiant change in your fuel air mixture and running.
Might be worth doing a pressure test of your crankcase
HxPaul wrote:johnnyXS wrote:that plug doesn't look good to me at all.
I disagree,from the photo the colour looks perfect,the earth strap is dark brown and the ceramic insulator is a lighter brown.The carbon build up on the plug is quite normal for a 2t.
garynonnah wrote:OK thanks will do compression check, what is a good pressure....
HxPaul wrote:johnnyXSwrote:
"THAT PLUG DOESN'T LOOK GOOD TO ME AT ALL"
I did
I did
I do not write in capital letters Paul![]()
Might I respectfully request that you read and quote the whole of my post in its entirety
Please do not remove just one small part of my post in order to quote it out of context to imply something that I did not intend.
I respect your assessment and suggestion (although I do not concur ) and your right to voice it
I suggest you offer other members the same consideration
garynonnah wrote:Hi guys, just done a compression check, im getting a reading of 75PSI ...
Users browsing this forum: Google [Bot] and 61 guests
