strange noise
strange noise
Postby JBG584 » Wed Jun 17, 2015 12:48 pm
Hi
dont know if you can help but my series 2 has developed a tinkling sound noticeable at low revs coming from flywheel area, its quite distinct .Have checked everything I can see, seems all nuts etc are tight any suggestions.
Cheers Ray
JBG584
Re: strange noise
Postby Digger » Wed Jun 17, 2015 2:55 pm
I'd check the rivets on the flywheel boss.
I had a noise like that which I ignored. I stopped ignoring it when the flywheel and boss parted company.
Digger
Re: strange noise
Postby JBG584 » Wed Jun 17, 2015 5:42 pm
Ill check that
cheers
JBG584
Re: strange noise
Postby Adam_Winstone » Wed Jun 17, 2015 6:09 pm
I was recently asked to have a look at a mate's Jet200 that was refusing to tickover, with the owner thinking that it was probably a jetting/air leak issue. When he came over it too was making a flywheel scraping type noise, which I didn't like, so I stripped the AFR light flywheel off to check for contact and found that this had a loose magnet cover plate that was lifting and clicking when the flywheel rotated. Frustratingly, this is the second new AFR light flywheel that has done this on the same bike! The engine was one that I built for him using all new parts and the crank runs true (MEC Race) so there is no reason why this should have failed.
This bike is a regular commuter ride and rally bike, clocking up the miles and has been extremely reliable other than the flywheels. To get him back on the road I swapped it for a SIL one (lend rather than have) and the bike immediately ticked over and ran like a dream. AF have replaced the 2nd faulty light flywheel with a standard short fin SIL item and have assured the owner that failures are VERY limited.
As previous response suggested, check for flywheel and stator issues before anything else.
Adam
Users browsing this forum: No registered users and 56 guests
