Indicator Setup (inspired by Peejay)
Postby Donnie » Tue Jun 16, 2015 7:39 pm
here viewtopic.php?f=10&t=3432&p=27913&hilit=indicator#p27913
So, Im going a different way for my Series 2, but Ive wanted to have a shot at this for some time.
I'm not using led though, im sticking with 3w festoons front and rear and wondering if it matters what sort of indicator relay is used? there seems to be 2 pin and 3 pins and I have no idea about these? Im also assuming that the relay is the same as the flasher ?
Daft questions I know, but never having to do this before it's new territory
Donnie
Re: Indicator Setup (inspired by Peejay)
Postby grandpa » Tue Jun 16, 2015 7:52 pm
Hi Donnie,
Yes flasher is the relay .Note if you are using conventional bulbs use WRE06 3pin relay(mechanical bi metal strip type).the third pin is for the idiot warning light.If you cannot see the indicators from a sitting position you need an idiot warning light.
I have an led in my speedo
Grandpa
grandpa
Postby Donnie » Tue Jun 16, 2015 8:35 pm
Aha! so thats all the 3rd pin does then! Im definitely fitting a buzzer, would that wire to the 3rd pin I wonder?
And do I need an idiot light for the mot?
Donnie
Postby Digger » Tue Jun 16, 2015 9:20 pm
Donnie wrote:Aha! so thats all the 3rd pin does then! Im definitely fitting a buzzer, would that wire to the 3rd pin I wonder?
As indicators weren't a requirement when it was first registered you can tape them up for the MOT.
You'll need a friggin loud buzzer!!!!!!!!!!!!!!!!!!!!!
Digger
Postby peejay » Tue Jun 16, 2015 9:28 pm
will 3 watt festoons be bright enough?
why do you not want to use leds then, i'm curious.
Postby Shaun » Tue Jun 16, 2015 9:32 pm
If it was a car, an 'audible warning' would be allowed, but its not, so a 'tell tale' must be fitted, or the indicators fitted so they are visible from the riding position.
Then we have Diggers option of tape, which is also perfectly acceceptable :)
Shaun
Postby Donnie » Tue Jun 16, 2015 10:01 pm
I could tape them up but if Im going to the bother of fitting the system its not hard to add one more piece surely?
as for a buzzer, ordered this one, i'll see if it's enough or not i guess http://www.ebay.co.uk/itm/RVFM-12-v-90- ... 20fd163e39
Donnie
Postby Donnie » Tue Jun 16, 2015 10:03 pm
peejay wrote:will 3 watt festoons be bright enough?
Yep, will be more than bright enough as im running a wassell and battery. Already done a quick test or the lights im using and they're quite good.
Donnie
Postby Donnie » Tue Jun 16, 2015 10:04 pm
Shaun wrote:If it was a car, an 'audible warning' would be allowed, but its not, so a 'tell tale' must be fitted, or the indicators fitted so they are visible from the riding position.
So definitly a warning light required then if I want to avoid the tape option. :D
Donnie
Postby MK Monty » Wed Jun 17, 2015 10:43 am
I have both idiot light and a flasher with a beeper built into it. The flasher is under the horn casting and I have had to put tape over it as it's very loud yes it's hard to here at speed but annoys the f.....out of my club mates normally the Vespa riders who only turn them off when they change direction.
MK Monty
Postby Donnie » Wed Jun 17, 2015 11:38 am
:lol: :lol: :lol: lol
Donnie
Postby Knowledge » Thu Jun 18, 2015 2:28 pm
Donnie, are you sure that you're sure? The Indian 12v indicators fitted at the factory were 18w incandescent lamps. A 3w incandescent festoon will have only a little more light than a speedo lamp, and in the daylight, you can't tell if the speedo is lit-up.
Even my LED indicators are about 3w. With good 12v DC supply, why are are going for such a small output festoon lamp? Is it the physical size of the lamp holder?
Martin
Postby grandpa » Thu Jun 18, 2015 5:05 pm
Hi Donnie,
As Knowledge remarks 3watt does not seem adequate. My indicator bulbs are 23watt.(12volt dc wassell with battery) It was the first thing I fitted for safety reasons car drivers expect to see a flashing indicator not someone flapping an arm. Indicators maybe not for purists but traffic density is much greater now than in the sixties.
Grandpa
grandpa
Postby Donnie » Thu Jun 18, 2015 8:30 pm
yep, definitely look more than bright enough, i am assuming they are 3w bulbs to be fair as that's what the description said.
I don't know if there are higher wattage bulbs available or not, not bothered to look into it to be honest
Donnie
Postby terryj » Thu Jun 18, 2015 8:49 pm
i fitted these stuck onto my rear number plate and wife following in car in daylight coudnt tell if they were on or not
http://www.amazon.co.uk/gp/product/B00M ... ge_o03_s00
may you at getting something i can fit cree led lights into
terryj
Postby Jono » Sun Jun 28, 2015 1:27 pm
Inspired to fit indicators to my GP for safety.
Have got all parts required (set of LED Indicators/Flasher Unit and GTS Switch ) just in process of making brackets for switch.
My question is how do I wire a single warning lamp to operate from either L/H or R/H lamps.The flasher unit I have is just feed & outllet, ideally I would like to just take a supply from which direction is activated and not cross feed to other indicators.
Any advice would be appreciated.
Jono
Jono
Postby MK Monty » Sun Jun 28, 2015 3:06 pm
The 3 pin flashers tend to use the 3rd pin. My ace well had idiot lights for left and right. The single led was a bit more challenging and needed to take a feed from both sides but using a diode to stop the flow going the wrong way and lighting the other side. Look at a diode as a one way valve lets the flow through to the led warning light but not back to the other side or set of lights. You will need 2
MK Monty
Postby Jono » Sun Jun 28, 2015 5:05 pm
Thanks for reply very helpful.
Do I just go to Maplins and ask for a diode or do I need to specify a size?
Sorry for such a basic question but iam only mechanical minded not electrical .
Any advice would be welcome.
Jono
Jono
Postby MK Monty » Mon Jun 29, 2015 12:56 pm
Sat by the pool in sunny Crete so limited access to the inter web. Maplins should be able to help. They will want to know volts and watts. Volts 12-15V watts bugger all if they are LEDS. The diodes will have a line on them. That's the way that they flow so the end closest to the LED from one feed, and the the same from the other side. The LED will flash but stop the electricery going back down to the other side.. Makes sence to me but I'm on my 2nd bottle of red :mrgreen:
MK Monty
Postby peejay » Tue Jun 30, 2015 12:03 am
MK Monty wrote:The 3 pin flashers tend to use the 3rd pin. My ace well had idiot lights for left and right. The single led was a bit more challenging and needed to take a feed from both sides but using a diode to stop the flow going the wrong way and lighting the other side. Look at a diode as a one way valve lets the flow through to the led warning light but not back to the other side or set of lights. You will need 2
reading this i'm glad i was able to have two led warning lights (so simple to wire up) :)
Users browsing this forum: No registered users and 86 guests
