However, do I need to include a 12v DC relay switch?
Paul
missing lynx wrote:got the same one to fit to my lynx I'm just going to run four wires (two from each wire on the loom) I use to run compressor air horn without a relay without any problems
johnnyXS wrote:using a relay means you can isolate battery power from your horn switch reducing the risk of fire.
Looking at how my horn/light switch cables are getting chewed to bits by the throttle and clutch wheels and gear change housing... I would not want to take a heavy duty cable from the battery up to the switch housing and back to the horns in case it got shorted out somewhere.
Users browsing this forum: Baidu [Spider] and 23 guests
