my LED indicator set up
Postby peejay » Tue Jun 02, 2015 1:17 pm
hi peeps
i've looked long and hard at what others have done, here's my version.
GTS indicator switch
front indicators
rear indicators
i've had to cut the angled part of the lug off and re-drill it
at this stage i'm keeping hole drilling/welding to a minimum till i'm really happy with things.
stainless switch brackets.
easy option for fitting front indicator is to simply drill a whacking great hole in the legshield and hide wires in toolbox, but i didn't want to do that!
stainless 2 piece clamp
lamp bracket mild steel and mattblacked
wires neatly out of the way
having the luxury of a C to C stylee flyscreen i've fitted 2 warning lights but one is ok to comply with MoT
i have the room to fit a spare flasher unit under the L/H panel, near the battery tray
rear rack has additional 6mm bar welded on to protect the led flasher
rear indicators are angled up slightly to be in the following driver's eye line, well that's my theory anyway!
well that's the basics of it, it's had a thorough shake down test on the recent Coast to Coast event and works really well :D
my special thanks to clubmate Dave "the doctor" Jones for all the specialist bracketry.
any questions just ask and i'll try to answer them but remember i'm not an auto electrian ;)
Re: my LED indicator set up
Postby Donnie » Tue Jun 02, 2015 4:51 pm
I actually like that, Ive often wondered about fitting something for fun rather than anything else but the switch is always the big issue for me, like how you've done that though.
One question, how do you cancel the indicators? ie i assume left for left, right for right, but does the button return to central then you push in to cancel or someother way?
Donnie
Postby peejay » Tue Jun 02, 2015 5:06 pm
Donnie wrote:One question, how do you cancel the indicators? ie i assume left for left, right for right, but does the button return to central then you push in to cancel or someother way?
hi Donnie, the beauty of the GTS switch is just press in to cancel no matter where it is, no faffing about to return it to centre position :)
Postby Donnie » Tue Jun 02, 2015 6:03 pm
thought it would be, nice one.
Donnie
Postby gaz_powell » Tue Jun 02, 2015 10:10 pm
Looks good
very nice and neat !
Gaz
Postby peejay » Tue Jun 02, 2015 11:01 pm
gaz_powell wrote:very nice and neat !
thanks gaz
the white lenses just don't notice to joe public....................till i turn them on!
Postby Timexit17 » Wed Jun 03, 2015 10:28 pm
I knew GTS's would prove useful for something eventually!
:lol:
Great work by Doctor Dave again.
Timexit17
Postby peejay » Thu Jun 04, 2015 10:55 am
Timexit17 wrote:I knew GTS's would prove useful for something eventually!
:lol:
you are so unkind Tim, but then i do admit to riding one occassionally :)
Postby kennystag » Thu Jun 04, 2015 9:47 pm
Hi nice job. Where did you get all the parts from, and what was the cost, as i am thinking of doing that set up myself.
Stag
kennystag
Postby terryj » Fri Jun 05, 2015 8:49 am
i fitted some of these
http://www.amazon.co.uk/gp/product/B00M ... ge_o01_s00
as they looked as if they would blend in trouble is just not bright enough wife following in car in daytime coudnt be sure if they were on or not
buy cheap buy twice strikes again
terryj
Postby peejay » Fri Jun 05, 2015 8:53 am
terryj wrote:i fitted some of these
i agree there are naff ones out there, i returned some that were useless but the ones i have used really work
Postby peejay » Fri Jun 05, 2015 11:28 am
kennystag wrote:Hi nice job. Where did you get all the parts from, and what was the cost, as i am thinking of doing that set up myself.
Stag
hi stag
all indicators and flasher unit came from ebay, indicator switch from AJ Sutton.
front indicator - £6.00
rear indicator - £16
flasher unit - £2 (make sure it's for LED lamps)
genuine Vespa turn indicator switch £11.20
hope this helps you :)
Postby peejay » Fri Jun 05, 2015 11:30 am
peejay wrote:
kennystag wrote:Where did you get all the parts from, and what was the cost, as i am thinking of doing that set up myself.
Stag
hi stag
genuine Vespa GTS turn indicator switch £11.20
Postby peejay » Fri Jun 05, 2015 12:28 pm
forgot to mention the warning light!
this is the first one i fitted:
problem was that when switch was operated the lamp was dim and dimmer! what's the point of a DIM warning light?
so i cut it open to find this:
no wonder it's dim, that green lense is 10mm thick!
i've now fitted a capless red led bulb in the housing
i've sealed the end with opaque plastic to make it waterproof.
Postby kennystag » Fri Jun 05, 2015 4:24 pm
Hi Mate,
Thanks for taking the time to send all that good information.
Stag
kennystag
Users browsing this forum: No registered users and 147 guests
