Needle clip - too weak or too rich
Postby Raveydavey » Fri May 22, 2015 7:18 pm
this is doing my head in...
Phbh 30 on rt225(230 with 60 mm crank)
Just to the end of running in now so time to sort the lumpy richness that you patiently have to live with at these times.
I've got it spot on to 1/4, by changing the slide to a 50, mixture is 2 turns and ticks over nicely, over 3/4 is spot on, picks up very nicely but that while mid throttle, atomiser and needle range is all over the place.
Initially had an av266 Needle jet with an x2 needle. It was too rich on 3rd clip and too weak on last clip. Just put in an av264, same needle, it's too rich on 2nd clip and too weak on the 3rd. So by changing the atomiser I've moved the problem down the needle but no closer to solving the issue. I suspect I need to change the needle but not sure if I'm looking leaner or richer.
What say the oracle?
Raveydavey
Re: Needle clip - too weak or too rich
Postby Raveydavey » Sat May 23, 2015 4:13 am
Think I've found the answer on this thread post by davetomo, originally written by Adam winston
viewtopic.php?f=6&t=160
I need a leaner needle To make it richer later. Simple really :)
Raveydavey
Postby Markpm » Sat May 23, 2015 8:30 am
You can get half clip spacers but no idea where from ?
Markpm
Postby col68 » Sat May 23, 2015 6:11 pm
Have you tryed a x13 needle with an av266 I run my tsi 230 with a 60 mm crank on 1 . think it is second clip up from bottom . Dynoed by diablo moto . col
col68
Postby Raveydavey » Sat May 23, 2015 6:44 pm
Cheers for the replys. I found I had an air leak today on the manifold, jubilee clip had become loose :shock: running rich now on 3rd clip up to 3/4 and then lean.
Just ordered x13 needle and a 130 and 132 main...running 128 and that's lean. Feel I'm getting close now.
Will put the 266 back in when I get the x13 and see how we go. Patience is something you learn :roll:
Raveydavey
Postby Raveydavey » Sat May 23, 2015 6:45 pm
col68 wrote:Have you tryed a x13 needle with an av266 I run my tsi 230 with a 60 mm crank on 1 . think it is second clip up from bottom . Dynoed by diablo moto . col
Just out of curiosity what main have you got in there?
Raveydavey
Postby Raveydavey » Sat May 23, 2015 6:46 pm
Markpm wrote:You can get half clip spacers but no idea where from ?
I already have one mark :geek: :D
Raveydavey
Postby Toddy » Sat May 23, 2015 8:46 pm
Eurocarb dellorto sell them and a few dealers
Postby col68 » Sun May 24, 2015 6:24 am
I have a 135 main jet
col68
Postby Wack » Sun May 24, 2015 9:42 am
Stick with the 266, even 268 if it runs ok with the x2 at 1/4 throttle then try x13 and x7 possibly with a 1/2 shim. They are all the same diameter just different taper lengths. Better to be safe than sorry when cruising at 1/4 throttle.
Postby Raveydavey » Sun May 24, 2015 4:24 pm
Wack wrote:Stick with the 266, even 268 if it runs ok with the x2 at 1/4 throttle then try x13 and x7 possibly with a 1/2 shim. They are all the same diameter just different taper lengths. Better to be safe than sorry when cruising at 1/4 throttle.
I started with a 45 slide, x2 and 266 but was spluttering like a drunkered up to 1/4, so 268 would be too much I think. When I changed slide to a 50 it was then spot on up to 1/4 and really rich after. Only changed to 264 because the x2 only seemed slightly ok on last clip with a shim. In hindsight Should have tried a leaner needle first. Oh well, I'll have loads of spare parts when I'm done :roll:
Raveydavey
Postby Raveydavey » Sun May 24, 2015 4:29 pm
Thanks.
Have just ordered 132 and 134 , not as tuned as a ts1 so should be close.
Raveydavey
Return to Carburettors
Users browsing this forum: Bing [Bot] and 43 guests
