Looks like an LI housing with a home made bulb holder.
GP unit is plastic with ribs on the top running front to back.
The lens should sit more parallel to the line of the rear of the frame.
Warkton Tornado No.1 wrote:Buzz
So have you seen a "black plastic moulded rear light unit" on Spanish scooters?
They appear very similar to the later Jet units. However, the Spanish ones are steel & deeper, front to back.
The black plastic moulded rear light unit that I have to hand has the following moulded in to the inside as though the mould was stamped:
F. B. 2063
Regards
Users browsing this forum: Google [Bot] and 70 guests
