Oh it doesn't normally tick over quite so high as it did, checked to see if the hose/carb/manifold were a cause but once again- all seemed ok, don't think it would be related
nickw wrote:No spark would suggest green wire problem (after changing forks) and have you disturbed the throttle cable? I suspect you've probably looked already at these.
coaster wrote:I would have a very careful look at the clamp bolt, I noticed the other day that I'd trapped a wire under mine when I had the forks out a while back. It was a feed to my lights which had been working but suddenly stopped, presumably when the insulation finally gave out
Users browsing this forum: Baidu [Spider], Google [Bot] and 103 guests
