22 dellorto sticky float?
Postby a7grenade » Wed May 13, 2015 10:03 am
hey chaps; stopped using my 175 top ended 150 series 3 last year when my carb flooded-stripped it down on side of road and got home
used again a week or so later and again it bogged down-fuel pissing out of two overflows
stripped down carb at weekend and cleaned with carb cleaner-blew out jets
ran well-for a bit
did it again and ran out for half hour-parked up-left for half hour-started up and can home
very soon i realised carb was flooding again so kept throttle open to use the fuel up
I'm running a red tipped float needle and the float seems airtight (the needle is hardly used-milage wise)
needle seems to be clear in its hole
wondered what you all thought?
carb oiled up? from fuel/oil mix sitting?
red tip damaged? (looks fine)
float knackered? it is original 60s i think
float pin bent?
thanks
a7grenade
Re: 22 dellorto sticky float?
Postby hullygully » Wed May 13, 2015 10:13 am
remove the carb from the manifold with the fuel line intact, remove the float bowl, turn the fuel on & off & have a play with the float, if the fuel stops flowing then detach the float & place it in a container with fuel in, if it sinks then its punctured.
Postby a7grenade » Wed May 13, 2015 9:35 pm
Will try that again, I did it once but it looked ok. Might be a tiny hole I guess
a7grenade
Postby northernpete » Thu May 14, 2015 6:49 pm
Mate had exact same problem and we mentioned it to lads at Scooter Restorations.....they reckon it may be ethanol in fuel causing float bowl to swell up and stick.
He bought a new jetex float bowl and problem seems to be solved...(fingers crossed) :?
northernpete
Postby northernpete » Thu May 14, 2015 6:51 pm
Just re read original post and noticed you had an original float......ditto my mates.
northernpete
Postby a7grenade » Fri May 15, 2015 12:25 pm
was beginning to think it might be ethanol as it ran fine for a year after rebuild-thanks
will get one
a7grenade
Postby Scooter Paul » Fri May 15, 2015 2:02 pm
It was the ethanol, or highly likely. It eats plastic and rubber that isn't ethanol resistant. Ask Ducati they had to recall petrol tanks that were melting.
Paul
Scooter Paul
Postby Scooterslag » Sat May 16, 2015 1:26 am
northernpete wrote:Mate had exact same problem and we mentioned it to lads at Scooter Restorations.....they reckon it may be ethanol in fuel causing float bowl to swell up and stick.
I've had this problem a couple of times- I just put it down to sedative causing the needle to stick, wonder if anyone will make a ethanol resistance float? maybe the new Scootopia 22mm carb will have such a thing? Paul
Postby northernpete » Sun May 17, 2015 7:22 pm
Guys at Scooter Restorations reckon the Jetex ones are suitable..........
northernpete
Postby Ivor the engine » Mon May 18, 2015 11:34 am
Hi,
I carried out a job on a bike and had this as a simialar / exactly the same issue.
I looked at the float, genuine Dellorto. no problems with the balance / weight. I had a spare genuine one from a parts fair and so I tried this as part of an elimination process.
Fitted / replaced the carb completely. Job done. no further gushing petrol from the carb. Although the large fuel sump 'O' ring / gasket looked worn or thin, this wasn't the issue.
On comparison between the two floats, where the float needle engages the float in the ' V ' slot, this appeared to be worn and looked like a ' U ', thus the needle was loose and although not seen when completely replaced, there appeared to be some slop in the needle engaging within the carb due to this wear.
After all this waffle, try a replacement float!
Hope this helps,
Regards,
Ivor.
Ivor the engine
Postby a7grenade » Wed May 27, 2015 3:00 pm
Ivor the engine wrote:Hi,
Hope this helps,
Regards,
Ivor.
now that! makes sense-thanks
I've tried an old one from another carb and it flooded straight away but the needle is loose in both and that would make sense
as the needle is less than 500 miles old (red tipped too) but sloppy would make it sit badly
nobody likes it sloppy
thanks ivor
a7grenade
Postby maz » Sun May 31, 2015 12:27 pm
Had similar probs on lots of Jetex carbs........... solved problem by polishing the brass tube that the float needle slides up and down in. I found the best way to polish the tube is to cut one of those ' cotton tipped bud/sticks ' in half and put the none cotton tipped end in a dremmel and dip the cotton tip in brasso before inserting into the brass tube and polishing............ worked a treat on all the carbs I've had probs with.
Maz
maz
Return to Carburettors
Users browsing this forum: Majestic-12 [Bot] and 20 guests
