painted my scooter from rattle cans
Postby kennystag » Sun May 10, 2015 6:38 pm
Hi all I painted my scooter mat black with rattle cans, but when petrol or thinners touch it looks a mess, it even marks when I touch it, is there anything I can get to spray over my scooter to stop this happening.
Stag
kennystag
Re: painted my scooter from rattle cans
Postby dave411 » Sun May 10, 2015 6:51 pm
:shock: :shock: shit,I am doing the same.What paint are you using?Hope its not what I am using.
dave411
Postby Adam_Winstone » Sun May 10, 2015 8:04 pm
You can buy petrol resistant lacquer from a number of places and this does stop the problem of the petrol melting/marking. Halfords sell it, as does my local motorist discount. I use it on rattle can sprayed petrol tanks any/or and other areas that'll come into contact with petrol... just about everything if you plan to run an open mouthed carb! I even spray the area of arch around the petrol flap as it is pretty common to drip a bit when filling up. I didn't spray my panels and they now show marks, which I like to think of as patina ;)
Postby coaster » Sun May 10, 2015 10:06 pm
Patina, I like that Adam ;)
I think the petrol resistant lacquer is your only option but the panels sprayed with it are going to be glossy unfortunately :shock:
Postby missing lynx » Mon May 11, 2015 3:23 pm
another thing even though the temptation will be hard to ignore don't try and wipe it dry as this makes a hell of a mess and if you use paper towel it sticks. halfords sell petrol resistant laquer and also I used a square of thick cloth with a hole in the middle to put over the the frame to soak up any drips
Postby coaster » Mon May 11, 2015 6:24 pm
missing lynx wrote:another thing even though the temptation will be hard to ignore don't try and wipe it dry as this makes a hell of a mess and if you use paper towel it sticks.
Yes, I found that out to my cost a few years ago just after I'd put spray can acrylic lacquer on my new 2 tone paint job, fuel overflowed onto the panel so grabbed some paper towel to mop it off the panel only to find blue paint on the towel. That meant it had eaten through the lacquer in a matter of seconds :? Still as Adam says, it's just 'patina' :lol:
Postby kennystag » Tue May 12, 2015 12:47 pm
Thanks for all the replys, I am using paint from pound land, believe it or not for £1 a rattle can it is really good paint, I have used it before with no problems until now.
Stag
kennystag
Postby dave411 » Tue May 12, 2015 5:50 pm
Not that good then.I am going to give one of my painted bits a petrol test.Will let you know what happens.
dave411
Postby kennystag » Tue May 12, 2015 6:47 pm
Dave the Paint is very good for some things but not near petrol unless you put lacquer over it. I bought this lacquer, I will let you know how it goes.
Stag
Autotek AT000CL500 Clear Lacquer Spray Paint 4 Cans 500ml
kennystag
Postby dave411 » Tue May 12, 2015 7:01 pm
Just got home,straight in the garage.Got a rag and soaked it in best un leaded,wiped and rubbed the inside of the tool box door,no sign of it coming off.But,just to be sure,will do it again later on the same area
dave411
Postby kennystag » Tue May 12, 2015 7:37 pm
I think the biggest mistake I made as I don’t think I gave the paint enough time to cure, as the paint is very good worth a pound, I have used it for doing the sills on my campervan, and on my trailer wheels, I am sure it will be ok with the lacquer. The scooter looks good mat black, I am very happy with it.
Stag
kennystag
Postby dave411 » Tue May 12, 2015 9:50 pm
If you are happy with it that all that matters.I am sure it will be fine with the laquer,but if its a gloss then it will loose its matt finish.
Got any pics you an post?
Dave.
dave411
Postby simmo » Wed May 13, 2015 5:38 pm
Might prove useful to know - I did a cutdown last winter and sprayed it with Halfords satin black, it came out ok (well I think it did!) and the spitback out of the carb just wipes off no problem. Very little difference between satin and matt imo and the satin seems to be petrol proof.
simmo
Postby kennystag » Wed May 13, 2015 6:05 pm
The mat and satin black from pound land, or is it pound world I get them mixed up, it is really good paint, and it goes on a treat, What can you buy for a pound these days. Just waiting on the lacquer to finish the job off
Stag
kennystag
Postby Martin s » Thu May 28, 2015 6:11 pm
http://www.amazon.co.uk/Canbrush-Spray- ... 6040414375
Apparently this is petrol proof, although not that cheap.
Martin s
Postby kennystag » Thu May 28, 2015 6:28 pm
Thanks for that.
Stag
kennystag
