BGM upside down?
BGM upside down?
Postby Cheersdude » Mon Jun 23, 2014 3:07 pm
I've got BGM front dampers, but can't get them to fit with the anti-drive set up, so have turned them up the other way.
Will this make a difference?
Cheersdude
Re: BGM upside down?
Postby foremanbob » Mon Jun 23, 2014 5:01 pm
Dirt will collect on the oil seal face and eventually cause a leak...
foremanbob
Postby Rich Oswald » Mon Jun 23, 2014 6:51 pm
Apart from the fact that they don't look right that way do they foul the bolts or would they foul the brackets without the bolts at all?
Postby Cheersdude » Mon Jun 23, 2014 7:33 pm
The bracket fine it's the bolts
Cheersdude
Postby Rich Oswald » Mon Jun 23, 2014 8:21 pm
In that case try getting some allen head bolts that sit almost flush.
Postby Scooterlam » Tue Jun 24, 2014 12:12 am
Technically, you've increased the unsprung weight.
If you notice it , you're a better man than me. :)
Scooterlam
Postby jonw » Tue Jun 24, 2014 12:59 pm
I don't have any BGM's but I understand they have adjustable compression dampening.
If this is the case you could remove the anti dive and increase the compression dampening to help tune out any brake dive.
jonw
Postby Cheersdude » Tue Jun 24, 2014 2:57 pm
I've ordered up some Allen bolts to see if that makes a difference.
Cheersdude
Postby Cheersdude » Fri Jun 27, 2014 11:05 am
Sorted
Thank you :D
Cheersdude
Postby Rich Oswald » Fri Jun 27, 2014 11:52 am
Nice one that's exactly what I meant,
Users browsing this forum: Baidu [Spider] and 48 guests
