sensors
sensors
Postby Scooterlam » Fri May 01, 2015 10:31 pm
I've got my self a egt cht gauge and need the sensors,
Can any one tell me how long the need to be to get to the head set.
Also what type I need for the cht.
,cheers
Scooterlam
Re: sensors
Postby foremanbob » Tue May 05, 2015 7:51 am
You'll need to be a bit more specific... the sensors are not all the same... different connections etc....
foremanbob
Re: sensors
Postby Scooterlam » Tue May 05, 2015 9:08 am
The cht has bullet connectors,
And the egt has the yellow two pin conector
Scooterlam
Re: sensors
Postby coaster » Tue May 05, 2015 7:16 pm
I think you'll find most EGT probes are the same (K type) and most are made in China. Personally I find the right angled type to last longer than the straight ones for some reason. The CHT ones do differ though, SOME are k type but others like the ones for the Kosso gauges so as said, more info on make of gauge needed.
Re: sensors
Postby Scooterlam » Tue May 05, 2015 7:55 pm
Ok,
It's a microlight products Inc gauge
Two sweep needles on a single face.
It came with an EGT sensor and loooking at it its just a case of extending the wire from the k type block to the gauge.
Trying to find a cht sensor that doesn't have to come from Hong Kong.
Scooterlam
Re: sensors
Postby coaster » Tue May 05, 2015 8:12 pm
Scooterlam wrote:Ok,
In that case it will be the K type CHT as well, don't worry about coming from China, they often give 2 to 3 week delivery times but often arrive in less than a week. Be prepared to swap the wires around as the gauges are polarity sensitive ;)
Most sensors seem to come with about 1.5 metres of braided cable which I just roll up and secure with a cable tie under the horn casting.
Colin
Re: sensors
Postby Scooterlam » Tue May 05, 2015 9:43 pm
Thanks Colin.
Scooterlam
Re: sensors
Postby carlos fandango » Tue May 05, 2015 10:21 pm
carlos fandango
