rossclark wrote:
What is the piston to bore clearance?
Captain Pugwash wrote:Did you check the clearance between the crankcase and the webbs on both sides & top and bottom while rotating the crank ?
Only rattles at low revs ? or it gets continually worse as the revs rise ?
Flywheel touching somewhere on the mag side on either the cowling, stator, mag housing itself or the nuts and bolts that hold the mag and stator in place these often gives a rattling rubbing scraping sound but might be worth looking to see if there's any witness marks.
Flat slide carbs often make a slight rattle clicking noise at tick over.
Captain Pugwash wrote:If it 6 thou in Line with but at 90 degrees to the gudgeon pin then I would say it's worn.
kevspeed wrote:Captain Pugwash wrote:If it 6 thou in Line with but at 90 degrees to the gudgeon pin then I would say it's worn.
650 miles though!!,something went wrong big time!!
kevspeed wrote:'Clatters' when hot and cold,piston definately not touching anything at top and bottom...........................BUT........................I HAVE JUST DISCOVERED SOMETHING AND ITS MY OWN BLOODY FAULT![]()
Normally (if im doing a job for someone else),ill check everything that arrives for that particular scoot,just to make sure there wont be any problems,BUT..... just lately,when ive had time to do my own stuff,ive been very slack,and just trusted what ive sent for being what it should be!,Obviously,when i eventually got the TS1 back after a 5 year break,i assembled it without checking everything,and just assumed it would be ready to go......................WRONG....................I have a grade 'A' barrel,with a grade 'B' piston,possibly the clatter being an undersize piston???????...DOH!
Users browsing this forum: Baidu [Spider] and 34 guests
