Aircraft grade clutch inner cable
Re: Aircraft grade clutch inner cable
Postby Nelly » Mon Apr 27, 2015 9:05 pm
I had a bit of trouble finding proper genuine Piaggio clutch inners last year when I rebuilt the engine. I ended up getting a complete cable from Wasp Performance, just to get the decent inner!
I may give these a try next time. Let us know what the quality is like if you get some.
Nelly
Postby jonoy » Mon Apr 27, 2015 9:09 pm
Ok will do
jonoy
Postby rossclark » Mon Apr 27, 2015 11:48 pm
I had to borrow a gear cable from a mate when rebuilding the pig as I bust one refitting the selector box. The cable he gave me was thinner than the usual ones, much more flexible and appeared braided rather than twisted.
I don't know what type it was.
Postby Warkton Tornado No.1 » Tue Apr 28, 2015 5:00 am
Sounds more 'Native American Indian' than Rastafarian......
Postby coaster » Tue Apr 28, 2015 8:49 am
Tony Hart wrote:
dave411 wrote:I meant the Airoplane :o
I thought it was a Tiger Moth but I'm relying on memories of Airfix. :oops:
I wouldn't do that if I were you ;)
Gypsy Moth (forerunner to the Tiger Moth) as flow to Australia by Amy Johnson
Colin
Postby phil23fair » Tue Apr 28, 2015 8:51 pm
In my opinion well worth fitting with nylon lined outer. They really improve the ease of clutch operation. All my scooters have 6 plate clutches with competition springs and you can pull the clutch lever in with two fingers. I fitted mine after a pretty bad accident that damaged my left wrist so badly I really struggled to pull in the clutch with a standard cable. I think it was Ian Frankland that suggested changing to braided clutch cables to give easier operation. It certainly worked for me.
phil23fair
Postby Donnie » Thu Apr 30, 2015 2:24 pm
I can't remember the last time i had a non aircraft :roll: grade cable snap to be honest, but then I tend to ensure i use nylon lined sets, properly lubricated and routed and ensure that the trunnions are copper greased etc. So im quite happy with my 1.50 inners 8-) 8-)
Donnie
Postby Digger » Thu Apr 30, 2015 3:58 pm
Donnie wrote:I can't remember the last time i had a non aircraft :roll: grade cable snap to be honest, but then I tend to ensure i use nylon lined sets, properly lubricated and routed and ensure that the trunnions are copper greased etc. So im quite happy with my 1.50 inners 8-) 8-)
That's fine Paul but I'm quite happy paying a little more - you can't take it with you. ;)
Digger
Postby Donnie » Thu Apr 30, 2015 4:26 pm
Very true, but it's more for me to spend while Im here :D :D :D :D
Donnie
Users browsing this forum: Google [Bot] and 55 guests
