Tim_Craig wrote:Thanks for the info Johnny, just to add a little more.
The system will be 12v AC non battery. Will a regular 12v horn be ok?
I have the complete Electrex system, just want to add an extra CDI & regulator. Not sure if Electrex sell them seperately hence going for BGM.
Hope this makes things a little clearer.
Thanks Tim.
Wack wrote:Stick with the 6 v horn it'll sound louder.
johnnyXS wrote:Tim_Craig wrote:Thanks for the info Johnny, just to add a little more.
Thanks Tim.
apologies Tim I misread your post. You currently have a AC system and you're sticking with it so you'll need 12v AC bulbs not DC .
As Wack says try the 6v horn before buying a replacement ,it might work fine .
MK Monty wrote:johnnyXS wrote:Tim_Craig wrote:Thanks for the info Johnny, just to add a little more.
Thanks Tim.
Bugger I was having problems getting those 12v DC bulbs the AC ones should be easier to find... I hope
dickie wrote:Tim, it's difficult to say for certain without having details of the electrex characteristics, which will be tricky as they're not common.
That said, I'll be very surprised if it doesn't work with the bgm regulator. Also I'd expect it to work with the cdi too.
Do you have any details of the electrex system? A wiring diagram would be great.
Also electrex systems had fixed timing but i heard that they now have an auto retard/advance system. Do you know what you have?
One point though; I've used electrex parts on lots of bikes (not lambrettas) and they have NEVER failed. I may have been lucky, but i suspect that they're just good quality.
soullad wrote:Fitted one to a mates bike last year, I think he kept the wiring diagram so I can ask him for you.
I used a standard loom, after all, the CDi is practically identical and the outputs from the regulator are both AC and then a cd feed for a possible battery circuit or charging line etc.
Now he has since fitted another regulator to the lighting output, in effect running 2 regulators, so the answers are both yes and yes to your questions, I think![]()
By the way, it hard the auto retard system, starts and runs well. I rode with him to Switzerland last year and it never missed a beat. The Electrex system is a great piece of kit, it's just Electrex themselves have appalling customer service, so I've no idea what if any replacement parts will work etc etc , for more info see my jet set piece on the system. If they sorted this out, I believe it would be THE system of choice bar none.
