pip wrote:Had similar problem with mine when hot, if I turned fuel off and opened throttle full would start no problem. I put all Dellorto jets in the jetex and a new float needle and it's been fine ever since. Saying that though poor starting when warm can be a sign of worn rings or bore.
Wack wrote:Sure it's not the clutch slipping when hot ?
