going backwards...
going backwards...
Postby simmo » Sat Apr 04, 2015 4:10 pm
Strange one this- my RB225 has started playing up. Took it out yesterday for the first time in six months, three miles down the road and the engine dies on me, roll to a stop and its ticking over nicely, pull away again and it will not rev past about 1800rpm, ie 30ish mph. Engine cools and its fine for another three miles then the same thing happens again. Go home. Strip and clean carb (34mm dellorto) all fine. Tried new plug, cdi and fresh fuel.
Took it out again this morning, all fine for three or four miles then it starts again, stop on the side of the road, check a few things then put it into first, drop the clutch the bike goes.......BACKWARDS...... :roll: . Back into neutral, scratch head, back into first and off we go, 30mph, splutter splutter.... HOME.
Stator? timing? help !
simmo
Re: going backwards...
Postby Scooter Paul » Sat Apr 04, 2015 4:48 pm
It sounds like timing. Stator plate worked loose or woodruff key sheared?
Paul
Scooter Paul
Postby simmo » Sat Apr 04, 2015 4:53 pm
Thanks for that Paul,weird that it runs ok when cold, I'm guessing that when the stator warms up things start going wrong...never had a lammie with reverse before..!!
simmo
Postby mickey c » Sat Apr 04, 2015 7:48 pm
I had very similar problem 12 months ago, the reverse was interesting. My stator died very quickly afterwards & I guess it was the pick up but changed the whole stator & driven forward at proper speed & revs ever since.
mickey c
Postby Wack » Sat Apr 04, 2015 8:06 pm
Pick up box gives these symptoms although not had one go backwards yet.
Postby simmo » Mon Apr 06, 2015 11:45 am
Thanks for the replies gents, will change the pick up coil and check out the stator.fingers crossed....
simmo
Postby simmo » Mon Apr 06, 2015 5:10 pm
Message received and understood eden.... :D
simmo
