Locktite 510 ?
Locktite 510 ?
Postby Captain Pugwash » Fri Apr 03, 2015 1:13 pm
Is anyone using this on their engines ?
It's a gasket eliminatir that is supposed to be good to over 200c degrees
I'm thinking of trying it just to see how good it is.
Any feed back would be greatly appreciated.
Thanks, Mark.
Captain Pugwash
Re: Locktite 510 ?
Postby Dimitrios_231 » Fri Apr 03, 2015 3:56 pm
I had bought one in the past,
when I went to use it,I noticed that it was colored pink,
I threw it straight to the bin...
Just kidding :lol: :mrgreen:
Where do you want to use it Captain?
Dimitrios_231
Re: Locktite 510 ?
Postby Captain Pugwash » Fri Apr 03, 2015 4:25 pm
Dimitrios_231 wrote:I had bought one in the past,
May housing and barrel base.
Captain Pugwash
Re: Locktite 510 ?
Postby Dimitrios_231 » Fri Apr 03, 2015 4:50 pm
Ηave you run out of Threebond?
You won't find a better sealant for the base,especially if you don't use a gasket.
1184 is the current European code.
My local guy,he is a sealant guru,told me that previous code 1104 had a cancer causing ingredient,they stopped making it :shock:
You can use Loctite 5910 (black) for the maghouse,assuming that you'll use a gasket.
Next time that I'll go for a sealant,I can ask my guru about 510.
Dimitrios_231
Re: Locktite 510 ?
Postby Captain Pugwash » Fri Apr 03, 2015 5:12 pm
Yes I'm using the Threebond but I heard it was good stuff so thought I would try it.
Captain Pugwash
Re: Locktite 510 ?
Postby Dimitrios_231 » Fri Apr 03, 2015 5:29 pm
Good luck,let us know,I'm always interested in sealants.
Dimitrios_231
Re: Locktite 510 ?
Postby Wack » Fri Apr 03, 2015 10:25 pm
I also use Dirko hi-temp sealant as used by Audi,etc and Worb 5.The only thing with Threebond is the stringing gets everywhere :roll:
Users browsing this forum: No registered users and 38 guests
