Mikuni fit issues on an Avanti
Postby MickYork » Wed Apr 01, 2015 7:31 am
Just fitted a Mikuni TMX 35 on my Avanti. When I've fitted the petrol tank (12L bolt on type with cut-out) the top of the carb misses the cut-out and catches the tank. The carb' also stops the petrol lever from connecting to the tap arm (tried various positions). To get it running the carb' is now at an angle to miss the tank. Runs ok but this will lower the volume of the bowl which doesn't look the biggest in the world.
It appears that the slim-style of the Mikuni is keeping the carb' too close to the manifold (AF type). A longer manifold or rubber would probably solve the problem but are these available ?
Anyone else had this problem and any ideas to make it fit.
ta
Re: Mikuni fit issues on an Avanti
Postby Nobby » Wed Apr 01, 2015 11:31 am
Surely it's more an issue with the tank? ( the position of the cutout and tap ) rather than the kit And carb?
Nobby
Postby MickYork » Wed Apr 01, 2015 1:02 pm
It probably is.......other than sourcing a different tank , that may or may not fit, what's the options ?
Postby Dimitrios_231 » Wed Apr 01, 2015 1:12 pm
I was using the MB manifold,currently out of stock.
This was on a Rapido 250.
http://www.lambrettaspares.com/spares/2 ... 0064k.html
Fuel tap rod was routed in front of the carb,
I could also use breath sweet filter,vertically mounted under the panels.
Tank was a 12L with cutout (standard type look)
Dimitrios_231
Postby Dimitrios_231 » Wed Apr 01, 2015 1:16 pm
Found another pic,clearance was very good.
Ignore the Agusto and early DC conversion with a capacitor spaghetti junction,I was only testing.
Dimitrios_231
Postby Angry Bloke » Wed Apr 01, 2015 1:38 pm
I had a similar problem recently ( albeit on a GT Kit ) but a combination of moving the tank over by a couple of mm , jacking it up up a couple of mm and a slightly longer carb rubber sorted it
I believe Dave Brailsford calls it " the aggregation of marginal gains " :D
Have you tried a UJ for the tap issue - available from most model shops
Angry Bloke
Postby MickYork » Wed Apr 01, 2015 3:32 pm
Dimitrios_231 wrote:I was using the MB manifold,currently out of stock.
Thanks D. in fact it's the carb and filter I bought off you a while ago. I think the fact it's a bolt on tank is causing one problem, basically there's no movement on it what-so-ever. Regards the fuel tap, I suspect the MB manifold may be shorter than mine, but i'll try it across the front.
Thanks for replies keep them coming......
Users browsing this forum: Baidu [Spider], Google [Bot] and 98 guests
