60mm stroke crankshaft
Postby Jamjo » Fri Mar 27, 2015 12:25 pm
Hello all ,
Looking for some advice for what is the best 60mm x 110 stroke crank to use on a ts1 build and what if any are the benefits over the 58mm .also should it be welded to stop twisting Any advice on suppliers I would be grateful.
Budget is around the £200 -250 area
Thanks in advance
James
Jamjo
Re: 60mm stroke crankshaft
Postby dickie » Fri Mar 27, 2015 1:06 pm
More torque for the same rpm.
Can't rev as high due to increased piston and rod acceleration. Although I suspect port timings and exhaust would limit revs before this became an issue.
In simple terms "it'll gan faster"
Postby Captain Pugwash » Sun Mar 29, 2015 1:21 pm
Anyone using the BGM 60 x110 ?
Captain Pugwash
Postby Captain Pugwash » Mon Mar 30, 2015 12:00 am
Jamjo, this is a 60 mm x 107 mm rodded JB supplied crankshaft, this is going into a new engine build soon.
think it was about £200,
But I' also looking to get a 60 x 110 rodded crank for my Avanti, only like yourself i'm not too sure whats the best available within a budget.
good luck, Mark .
Captain Pugwash
Postby paul213 » Mon Mar 30, 2015 3:29 pm
have put a couple of bgm 60/110 cranks in ts1's ive built for people no bad reports from them so far, one was harry barlow tuned ( no further work done to crank i.e welded pin )
paul213
Postby joe swoonara » Tue Mar 31, 2015 6:25 pm
been using one for a couple of years , had the big end bearing changed and the pin welded before i used it ..........so far so good :D
joe swoonara
Postby Dimitrios_231 » Wed Apr 01, 2015 3:21 pm
I'm using the 60/110 BGM on my last build,
I'm not very impressed,
the threads for the nut were damaged plus I had some difficulties to fit the woodruff key,
on the positive side the clearance is good.
Dimitrios_231
