Rich Oswald wrote:Thank you to you all for your replies. Just one thing, my circlip is tack welded on, easy to dremmel it off but is this normal?
Wack wrote:The circlip is welded to the end cap to stop it pinging out which is what happens to that type of end can, remember Frescos? As you squeeze the clip together , pull n twist the tail stub out.
Digger wrote:Wack wrote:The circlip is welded to the end cap to stop it pinging out which is what happens to that type of end can, remember Frescos? As you squeeze the clip together , pull n twist the tail stub out.
Thanks - I was scratching my head over mine.
gaz_powell wrote:rich - dead easy
as said buy the role
take the big circlip out and pull out the baffle assembly - unroll the old packing and cut the new same size
don't wrap it too tight - you'll get a feel for how tight by the old stuff you take out.
I use this
http://www.ebay.co.uk/itm/Exhaust-End-C ... 1633559294
gaz
rossclark wrote:It its a bit sticky use a spring hook and hook it into one of the holes in the tube in addition to the pliers.
Rich Oswald wrote:Well Mark and Daz,i've had the circlip free of the groove, been pulling with the spring puller, had screwdriver behind it but can I hellers like get the twat out. What's stopping it?![]()
Users browsing this forum: Baidu [Spider] and 81 guests
