Evening all, does a fast flow fuel tap have a reserve setting as my lammy wouldn't start without the lever in the reserve position where as I normally ride with it on the on position all the time,
Thanks in advance
Phil.
pharrisRB225 wrote:Hi toddy I checked the flow earlier when I cleaned the carb out and it was fine it's never done it before or maybe I've never let the fuel level get so low,
bamrattle wrote:pharrisRB225 wrote:Hi toddy I checked the flow earlier when I cleaned the carb out and it was fine it's never done it before or maybe I've never let the fuel level get so low,
If you rode it a bit more it wouldn't get like it....![]()
pharrisRB225 wrote:Evening all, does a fast flow fuel tap have a reserve setting as my lammy wouldn't start without the lever in the reserve position where as I normally ride with it on the on position all the time,
Thanks in advance
Phil.
Users browsing this forum: Baidu [Spider] and 35 guests
