Ldi or should that be Lid ?
Re: Ldi or should that be Lid ?
Postby peejay » Fri Dec 19, 2014 10:21 am
liking this a lot :)
Postby Rich Oswald » Fri Dec 19, 2014 11:05 am
Nice work Russ :D
Postby carlos fandango » Mon Dec 22, 2014 12:13 am
Cheers fellas
Next up was the leggies
They had a a bit of tin worm in a couple of areas, this part being the worse one , i thought i could build up with weld and grind back to shape, but one touch with the welder just blew an even bigger hole :(
A patch repair was the only solution. so a piece of steel , a bit of bar, piece of Oak and a hammer.
Half an hour later
And another half hour :)
My welding is getting better (slightly) with practise . I brought myself a new welding helmet , so i can see what im doing now 8-) and i dont have to keep looking away :)
carlos fandango
Postby duncan1958 » Tue Dec 23, 2014 3:50 pm
Good for you having a bash at the welding.
If you have the tools at your disposal why not .
When I first started work in a panel shop there was no mig welder.
Only gas welding and my first try at welding was making my own "orange box"
Not an all together sucessful attempt.
If I may offer my observation of the unground welds.
They look to me as the gas might be either incorrect presure or the gas is getting blown away by a draft,I of course could be wrong.
I would not go as far as to say I am a MIG welding expert just many years of gluing cars back together using a MIG.
duncan1958
Postby carlos fandango » Wed Dec 24, 2014 1:22 am
Its a gasless welder Duncan :) so ive got no control over the gas :( which is probably why im getting a lot of splatter ? :( ........ im just happy if it glues together and holds :)
carlos fandango
Postby duncan1958 » Thu Jan 08, 2015 9:46 am
Well done for you ,I have never used a gasless welder what I do know is what you discribe on the splatter part,there is a spray you can get which will not stop the splatter but where the splatter lands makes for an easier clean up.
My arc welding leaves something to be desired ! As in could do better :)
duncan1958
Postby carlos fandango » Fri Jan 23, 2015 1:42 am
Well i stalled a bit over Christmas, but had a few hours on it this week :)
First problem was the seat , i havent seen a decent looking alternative seat on a LD. I toyed with altering an old Snetterton i had , but the most comortable position for me, is directly over the filler cap , and with a Snetterton what would of been a little uncomfortable :shock:
I love the look of the LD front seat with the two springs at the rear, the position is too far forward for me, but the position is again over the filler cap and would be impossible to access the cap :? so i came up with an idea to make the seat tilt. I tried it first with a wooden template, then went on to a carboard template to transfer to some sheet steel and fabricated a bracket .
It only needs to tilt by about 25 degrees to gain access to the tank, ive still to make a catch for it and a way to adjust it back and forth a little whilst riding :)
Another job was the fork stem, this is too short by around 12mm to reach the top of the leggies. So i found a bit of scaffold tube, turned down the id a little to get the chrome ring and race to fit , and tacked in place.
So this in turn, meant the forks were 12mm too short, but also the LD fork are threaded all the way up to the top unlike the s3 forks i had. If i used the S3 forks the LD handle bar clamp is a very sloppy fit as the diameter is reduced. So out with the grinder again and its cut and shut time. Luckily i had a piece of tube the same size and the id of the fork tube , and just needed a smidge off on the lathe for a snug fit :)
carlos fandango
Postby Vega125s » Fri Jan 23, 2015 10:43 am
My favourite build, brilliant work.
Vega125s
Postby carlos fandango » Wed Jan 28, 2015 11:32 pm
Thanks Vega125 :)
A bit more work.
I made a start on the seat catch. Take one 10mm coach bolt and one clutch spring :)
And a steel bracket some nut and a split pin :)
Ok its a little "agricultural" and needs a bit of refining :) but it works and with a seat cover on ............
And a bit of work on the panels. Fill the holes up, ready for panel clips.
And a bit of mesh for the vent holes
carlos fandango
Postby duncan1958 » Sat Jan 31, 2015 5:16 am
This is coming on a treat.
Keep up the good work.
duncan1958
Postby carlos fandango » Sun Feb 15, 2015 12:19 am
Not had too much time on it recently :cry: but did a little bit.
Converted the panels to to clip on type, with some parts donated by Mr T :) thx
A little bit of reshaping
and a channel welded to the panel
Hoping to have a few more hours on it on Monday :D
carlos fandango
Postby Toddy » Sun Feb 15, 2015 12:37 am
Nice job mate glad to help ;)
Postby carlos fandango » Sat Feb 21, 2015 12:10 am
Ive got as far as i can now with just spending my time on it, ive now got to start spending money now buying parts :( but looking forward to getting it built now :) I still havent got a paint scheme in mind ,so i think im just going to cover it in acf50 and get it on the road :D
carlos fandango
Postby Scooterslag » Sat Feb 21, 2015 1:24 am
carlos fandango wrote:Ive got as far as i can now with just spending my time on it, ive now got to start spending money now buying parts :( but looking forward to getting it built now :) I still havent got a paint scheme in mind ,so i think im just going to cover it in acf50 and get it on the road :D
Very cool and the rat look will go fine, good work fella' 8-)
Postby Adam_Winstone » Sat Feb 21, 2015 11:41 am
Excellent work :)
Postby Angry Bloke » Sat Feb 21, 2015 2:00 pm
Cool as - looking forward to seeing it 8-)
Angry Bloke
Postby AdiD63 » Sat Feb 21, 2015 2:10 pm
Brilliant, I'm always in awe of these projects.
AdiD63
Postby carlos fandango » Wed Mar 11, 2015 10:16 pm
Ive done a bit more on it over the last couple of weeks
Petrol tank needed extending. So out with the grinder, and a quick mock up to see how big i can go.
I settled on 65mm , cut a band and formed it by hand and eye, tacked it together and then got a welder to do a proper job on it.
After an initial pressure test found two pin holes, got those fixed and now holds 5psi :)
Fits a treat, extended the fuel tap rod by the same amount as well.
carlos fandango
Postby trev t » Thu Mar 19, 2015 3:46 pm
bloody love it, an LD that will be usable
trev t
Postby carlos fandango » Mon Mar 23, 2015 12:56 am
Thanks Trev t ....usable, thats the idea :)
Ive got the cableing and speedo sorted :D
carlos fandango
Users browsing this forum: No registered users and 771 guests
