Remote air filter
Remote air filter
Postby 68Sxandy » Wed Jun 18, 2014 8:42 pm
Hi again guys,
Can anyone let me know of any pro's and con's of using a remote air filter please. My SX150 is currently running with an open carb and therefore spraying fuel and oil all over my panel and floorboards, albeit it runs just fine.
Thanks for any advice .
68Sxandy
Re: Remote air filter
Postby Toddy » Wed Jun 18, 2014 10:57 pm
They run like your normal air filter box really , your carb may need re jetting
To suit though
Postby peejay » Thu Jun 19, 2014 4:06 pm
and of course no more spraying oil and petrol all over your panels and floorboards :D
Postby foremanbob » Fri Jun 20, 2014 8:27 am
And all that spitback will gather in the filter elbow, forcing you to take measures to deal with it; especially hot starting.
I deal with this by switching the fuel off in advance of stopping in an attempt to burn some of that spitback off.
A pro is that you want be drawing in sand and dust into your barrel, reducing wear on the barrel and rings.
foremanbob
Postby roli150lam » Fri Jun 20, 2014 9:51 am
I use an MRB filter that fits over the plastic bell mouth(on a dellorto carb).On my scoot the carb is not square to the panel,so has a gap between panel and filter at one side.It does soak up a lot of the spit back like this which has been a bonus & no re-jetting needed.My scoot runs well like this no starting issues at all.Effectively a sponge like this really.
roli150lam
Postby Train driver » Fri Jun 20, 2014 11:28 am
I used a K&N filter on my Rapido 225
https://www.treatland.tv/K-N-R-1100-mik ... filter.htm
https://www.treatland.tv/K-N-RU-2450-mi ... filter.htm
I was running a 24mm Mikuni TM carb
Train driver
