Tyre fitting
Tyre fitting
Postby Revvers » Mon Mar 09, 2015 2:54 pm
Hello all. Any crafty tips on fitting a new tyre onto a new rim, or is it just a matter of brute force and perseverance ??
Revvers
Re: Tyre fitting
Postby Rich Oswald » Mon Mar 09, 2015 3:10 pm
Standard split rims or one piece tubeless?
Re: Tyre fitting
Postby Revvers » Mon Mar 09, 2015 4:03 pm
Sorry should have mentioned that. Split rim
Revvers
Re: Tyre fitting
Postby davla » Mon Mar 09, 2015 4:37 pm
Lightly inflate inner tube. Insert tube into tyre. Wipe some tyre lube/gel around lip of tyre. Assemble rims on tyre and tighten nuts fully being careful not to pinch tube. Inflate tube which pushes tyre onto rim. Pretty easy as long as you have good rims. Buy a tyre breaker off eBay for about 30 quid which makes removal of tyres easy. Not much brute force needed.
davla
Re: Tyre fitting
Postby Rich Oswald » Mon Mar 09, 2015 5:06 pm
A tip that I use is, after putting the two halves of the rim together and lightly inflating the tube, use a lollypop stick to push the tube in and away from the rims so that it is not nipped. Obviously you can only do this so far until the nuts start to tighten but it always works for me.
Re: Tyre fitting
Postby 911hillclimber » Mon Mar 09, 2015 5:46 pm
Washing up liquid instead of tyre lube ok?
About to do 3 rims next week.
911hillclimber
Re: Tyre fitting
Postby Rich Oswald » Mon Mar 09, 2015 5:53 pm
I have never used any lubricant on the rims. Never needed to.
Re: Tyre fitting
Postby Revvers » Mon Mar 09, 2015 6:01 pm
Cheers guys. First attempt, inner tube squeezed out. Time to have another punt
Revvers
Re: Tyre fitting
Postby davla » Mon Mar 09, 2015 6:19 pm
911hillclimber wrote:Washing up liquid instead of tyre lube ok?
I wouldn't personally, the lube/gel evaporates whereby the washing up liquid won't....having said that if it's diluted sufficiently then will probably be ok. Or as Rich says, you can probably get away without using it at all...
davla
Re: Tyre fitting
Postby Wack » Mon Mar 09, 2015 7:04 pm
I'd rather use soap or talc as washing up liquid contains salt, that's why it's not recommended to wash cars with it.
Re: Tyre fitting
Postby coaster » Mon Mar 09, 2015 10:03 pm
Rich Oswald wrote:A tip that I use is, after putting the two halves of the rim together and lightly inflating the tube, use a lollypop stick to push the tube in and away from the rims so that it is not nipped. Obviously you can only do this so far until the nuts start to tighten but it always works for me.
A used credit card is also good 8-)
Re: Tyre fitting
Postby rossclark » Tue Mar 10, 2015 1:03 am
I've always used a round ended butter knife
Re: Tyre fitting
Postby Revvers » Tue Mar 10, 2015 7:01 pm
Sorry lads but looking at this again,surely you do have to force the rim with the hole for the inner tube onto the tyre first? Otherwise how do you get the valve to fit in the hole???
Revvers
