carb/ ignition probs
Postby a-teamlambretta » Sun Mar 08, 2015 5:42 pm
Having trouble setting up my rapido 240 reed valve motor. It's not reving out as it should.new varitronic ignition fitted and set at 24 deg st a fast idle and when reved it retards as it should. Have tried bgm stator and Indian flywheel prior to this and standard Indian set up. I have a vhsh 30 carb, same carb with all previous ignition set ups. I now have another vhsh to try. Can someone give me some ball park carb setting. Here is the motor set up
Rapido 240 Lth reed conversion
Varitronic ignition
B-race expansion
I need to know what slide,needle, atomiser,main,choke and idle jets.
It starts idlesand revs out ok up until 3/4 onwards. So I can only presume it'd carb set up. Cheers Simon
Last edited by a-teamlambretta on Sun Mar 08, 2015 5:58 pm, edited 1 time in total.
a-teamlambretta
Re: carb/ ignition probs
Postby MickYork » Sun Mar 08, 2015 5:47 pm
Could be a few things besides what you've said. I'd change plug and cdi unit 1st then also consider the reed petals....
Postby a-teamlambretta » Sun Mar 08, 2015 5:56 pm
Tried new plugs and as said this is the 3 ignition to be tried including cdi's
a-teamlambretta
Postby a-teamlambretta » Sun Mar 08, 2015 6:01 pm
When watching the flywheel with strobe it looks good not wandering or flicking about
a-teamlambretta
Postby coaster » Sun Mar 08, 2015 6:42 pm
a-teamlambretta wrote:......I need to know what slide,needle, atomiser,main,choke and idle jets.
What have you got in there at the moment?
Postby a-teamlambretta » Sun Mar 08, 2015 7:24 pm
I want to try the new carb, will swap all jets over etc but just wanted to make sure what I had in there was right. Will have a look and report back
a-teamlambretta
Postby a-teamlambretta » Sun Mar 08, 2015 7:51 pm
Here is carb set up
Slide 40
150 main
60 choke
55 Idle
Dq 265 atomiser
K3 or 13 can't see need a magnifying glass
300 float
What do you think?
a-teamlambretta
Postby dscscotty » Sun Mar 08, 2015 8:36 pm
When you say reed 240, what has been done to the cylinder?, has a boost or boost ports been added? Piston modifications? 150 main seems a little big?
Postby a-teamlambretta » Sun Mar 08, 2015 10:03 pm
Yes Work has been done. Single boost port no holes in piston but cut arche in piston skirt. Reeds are new. Motor sounds fit until 3/4 throttle, this on the stand not out on road. Ain't got front brake hooked up yet
a-teamlambretta
Postby foremanbob » Mon Mar 09, 2015 9:01 am
isnt anything like this is it? this only happened as the throttle was opened up
This was a dodgy pickup on a BGM stator that I replaced with a Ducati pickup, and all was good
https://www.youtube.com/watch?v=A8eaScGexBA
foremanbob
Postby a-teamlambretta » Mon Mar 09, 2015 9:16 am
foremanbob wrote:isnt anything like this is it? this only happened as the throttle was opened up
As stated, It's a varitronic ignition.
a-teamlambretta
Postby johnnyXS » Mon Mar 09, 2015 1:37 pm
24 degrees at fast idle is I believe max recommended advance .Your particular scooter spec may not be able to fully utilise that much total advance
I would be tempted to back the advance of 2 degrees and try that first to see if there was any improvement before messing with the jetting.
http://www.lambretta.co.uk/downloads/varitronic-fitting.html
johnnyXS
Postby a-teamlambretta » Mon Mar 09, 2015 2:41 pm
johnnyXS wrote:24 degrees at fast idle is I believe max recommended advance .Your particular scooter spec may not be able to fully utilise that much total advance
dont think its timing or ignition related as when i first started the motor i could not get any where near the sugested timings as the stator was fully clockwise. then i remembered i had changed the crank (time laps of a couple of years ) so re marked tdc which is around 40 deg clockwise from previouse setting ( keyway out on crank or flywheel??) anyway does not realy mater where the marks are. but ran the motor and still the same . the only thing that i have not changed is the carb hence wanting to try that before i pull the motor out. like i say the motor sound realy good until 3/4 and after throttle . will try and video it later and will nock the timing back to 21deg, thought it was 24 for some reason can see it making a shits worth of difference.
so what about carb settings ?? are they in the right ball park ?? . cheers for the input so far. simon
a-teamlambretta
Postby Fred » Mon Mar 09, 2015 3:12 pm
I'd come down on the main to 140 -145 see if it revs out
Fred
Postby weeks » Mon Mar 09, 2015 3:23 pm
dscscotty wrote:When you say reed 240, what has been done to the cylinder?, has a boost or boost ports been added? Piston modifications? 150 main seems a little big?
Fred wrote:I'd come down on the main to 140 -145 see if it revs out
As your only revving out on the stand this has got to be the easiest try ;)
weeks
Postby a-teamlambretta » Mon Mar 09, 2015 3:47 pm
will give it a try tonight
a-teamlambretta
Postby Wack » Mon Mar 09, 2015 7:00 pm
You will find that on a Varitronic , it hits a brick wall in neutral and will not rev out almost feels like you have blocked the exhaust. Wait till you get out on the road and I'm pretty sure it won't do it.
Postby missing lynx » Mon Mar 09, 2015 7:08 pm
it could be the exhaust
Postby a-teamlambretta » Mon Mar 09, 2015 7:32 pm
missing lynx wrote:it could be the exhaust
Had a change of exhaust, was dev-tour now B-race, no difference.
a-teamlambretta
Postby a-teamlambretta » Mon Mar 09, 2015 7:35 pm
Wack wrote:You will find that on a Varitronic , it hits a brick wall in neutral and will not rev out almost feels like you have blocked the exhaust. Wait till you get out on the road and I'm pretty sure it won't do it.
I have used a varitronic before with an imola and dev-tour, can't remember if was like this??.
a-teamlambretta
Users browsing this forum: No registered users and 26 guests
