bluelamb69 wrote:Advice needed please, did a few posts about problem with my SIL GP200 which only has 150 miles from new and had a problem when accelerating like it was jumping out of gear, after deciding to take chain case cover off i found the front sprocket bolt was loose and sprocket had worn the chain case but not enough to come through. Would like a bit of advice, if after only 150 miles the bolt came loose , what else could happen ? is a rebuild on the cards ?
