super steel on engine case.
Postby mark1 » Sat Feb 28, 2015 9:04 pm
I've just found out why my engine case is drawing gearbox oil into the top end, where I've had the cases welded there is a small pin sized hole going into the transfer port. Will it be ok to use super steel to fill it up or should I strip it all down and get it ali welded.
If I was running a standard top end I'd use the super steel but I've got an avanti top end fitted and obviously it will be an expensive mistake if it doesn't work.
mark1
Re: super steel on engine case.
Postby Wack » Sat Feb 28, 2015 10:28 pm
Chemical metal will be fine, just rebate the hole a bit to get a better bond. You could always pressure test after to be sure.
Users browsing this forum: No registered users and 39 guests
