Battery tray for series 3
Postby Patricks3179 » Wed Feb 25, 2015 8:58 pm
Hi I want to run two spotlights and a Lucas spotlight on my li 125 , I have no battery tray has its electronic I also have no leg shied toolbox , is there a way I can run them? I've looked at the series 3 battery trays and they all seem to be welded ones . Could I run another tray some where else ?
Patricks3179
Re: Battery tray for series 3
Postby Nelly » Wed Feb 25, 2015 9:43 pm
Have a look at this
viewtopic.php?f=10&t=2473
Nelly
Postby Patricks3179 » Wed Feb 25, 2015 9:48 pm
Thanks for the link Ill give it a look :D
Patricks3179
Postby grandpa » Thu Feb 26, 2015 9:21 am
Hi Patricks,
If you have an air box you can bolt a plate underneath, have a look at this
viewtopic.php?f=10&t=2322&p=17906&hilit=bolt+on+battery+tray#p17906
Grandpa
grandpa
Postby Knowledge » Thu Feb 26, 2015 1:42 pm
Don't limit yourself to traditional lead/acid batteries. Think about using a sealed lead acid gel battery as used in burglar alarms. Yuasa are the leading supplier and they do a very good pdf sheet showing all physical dimentions. They can also be mounted vertically or on their sides, giving lots of mounting options. Gel batteries don't leak like traditional lead/acid batteries, which is another bonus.
My Yuasa battery is half the size of the traditional battery, and gives plenty of power for my accessories.
Postby Patricks3179 » Thu Feb 26, 2015 8:45 pm
Thanks guys for all your help at least I have some options now , would you be able to provide me with details of your gel battery ?
Patricks3179
Postby Nelly » Thu Feb 26, 2015 9:09 pm
I've used this place for alarm batteries in the past, if I haven't been able to get them off the shelf at the wholesalers.
http://thebatteryshop.co.uk/
And the website for Yuasa is
http://www.yuasaeurope.com/eu/
Nelly
Postby terryj » Thu Feb 26, 2015 9:41 pm
Patricks3179 wrote:Thanks guys for all your help at least I have some options now , would you be able to provide me with details of your gel battery ?
got mine of amazon about £15 for a yusa 7ah
terryj
Postby Jono » Thu Feb 26, 2015 9:54 pm
Can recommend yuasa 7Ah Battery, have converted two Gp's(non battery ) using such a battery mounted vertically on a simple bracket mounted to air box & tool box . A great solution for a DC battery supply and use (grandpas ) easy solution to charge via a mini bridge rectifier from 12volt AC supply.
Jono
Ps : will try and post some pictures at the weekend.
Jono
Postby Patricks3179 » Thu Feb 26, 2015 10:13 pm
Could you show me a picture of how you mounted it using a bracket ? Thanks again everyone for your help!!
Patricks3179
Postby grandpa » Sat Feb 28, 2015 5:23 pm
Hi Patricks,
Pm sent
Note innermost bolt facing up this bolt is immediately above frame tube. If you do make up something similar you need to loosely fit this bolt as you slide in air box (as I remember) The tray shown previously on top picture is fitted to this airbox
Grandpa
grandpa
Postby kiewa » Sun Mar 01, 2015 12:14 am
Hi Patricks - I had the same problem - didn't want to fit a welded one. So I scratch-built an aluminium tray and a bracket to mount it off the back of the tool box. That required two holes drilled into the tool box, which i did without removing the tool box (even though for one of the holes the drill-bit was on a funny angle). I put a rubber gasket between the L-shaped mount and the tool box to protect the tool box from damage. As you can see from the pics I went a bit overboard with fuses and isolation switches.....
Steve (Australia)
kiewa
Postby grandpa » Mon Mar 02, 2015 1:05 pm
Kiewa,
That's a very neat battery tray down under..... way beyond my facilities and O-level metalwork skills .
Pommie Grandpa
grandpa
Users browsing this forum: No registered users and 99 guests
