Phbl carb
Phbl carb
Postby Cgt75b » Thu Feb 19, 2015 11:42 am
Has anyone got any jetting advice on a 25mm dellorto running through the air box no filter 225 cast iron, would rather be on the rich side if possible.
Any set up advice greatly appreciated
Thank you.
Re: Phbl carb
Postby Cgt75b » Wed Feb 25, 2015 5:04 pm
I'll reply to my own post how sad is that :lol: for anyone who needs a starting point
Pilot....52
Atomiser...AQ266
Needle...D22
Slide......40
Main Jet..110
Float needle valve 250
This is running through the air box no filter 48 mm clubman.
Re: Phbl carb
Postby rossclark » Thu Feb 26, 2015 1:15 am
I don't think its a very common carb choice for 225s, might be why the replies are slow.
No doubt having said that there will be hundreds who've used it ...
Re: Phbl carb
Postby Mag » Thu Feb 26, 2015 8:30 pm
I've got the same carb on my Stage 4 200 tuned by DSC, through the airbox (drilled and with the cone removed, BGM filter and MBGM Clubman.
Jetting is the same as yours except 105 main
Mag
Re: Phbl carb
Postby Cgt75b » Thu Feb 26, 2015 10:26 pm
Thanks lads I was starting to get a complex :D
It has a 26 mm Jetex on at the moment which has been great, except for an issue with hot starting, which I am hoping the 25 mm Phbl will sort out. The main reason for going for the 25 mm is so I can run through the air box, without having the jetting all over the place.
Cheers.
Re: Phbl carb
Postby Scooter Paul » Sat Feb 28, 2015 9:30 am
Worth bearing in mind that MB now sell 'big bore' air boxes which should preclude the need to drill holes in a standard box.
Paul
Scooter Paul
Re: Phbl carb
Postby Cgt75b » Tue Mar 31, 2015 5:23 pm
Cgt75b wrote:I'll reply to my own post how sad is that :lol: for anyone who needs a starting point
Pilot....50
Atomiser...AQ268
Needle...D26 clip third one down.
Slide......40
Main Jet..102
This is running through the air box no holes, with the filter now, 48 mm clubman.
Updated, still not quite happy with it yet.
Plug is a light brown colour, ideally would like it to be a bit richer.
Return to Carburettors
Users browsing this forum: Bing [Bot] and 42 guests
