Front Dampers
Front Dampers
Postby landybretta » Tue Feb 17, 2015 6:15 pm
I need to replace the front dampers on my LI Special (185) fitted with standard drum brake.
Has anyone used the MRB non adjustable ones>
Shock absorber (shocker, damper) front, Pair Silver, retro slim type, non-adjustable.
BGM 6Ts style front shock absorbers to be used with gaiters.
These dampers are not adjustable, but are set up to give the same dampening rate like the BGM adjustable front dampers.
landybretta
Re: Front Dampers
Postby weeks » Tue Feb 17, 2015 6:43 pm
These ? Not used them myself but look a nice bit of kit
Interested to know peoples views on them too
weeks
Re: Front Dampers
Postby a-teamlambretta » Tue Feb 17, 2015 8:53 pm
I have a set on my series 1, although I have not been out on the road yet to try. They seemed have a nice smooth action when operated by hand not at all notchy like the Indian escort type
A good upgrade over standard if you don't feel the need for adjustable ones.
a-teamlambretta
Re: Front Dampers
Postby Storkfoot » Tue Feb 17, 2015 9:48 pm
I fitted them to my S2 a couple of hundred miles ago. They replaced a set of Indian (non-Escort) dampers. They are an improvement but, in my case, I think they have highlighted that I need a better rear shock.
Probably a bit too early to give an unqualified thumbs up but I wouldn't put anyone off buying a set.
Re: Front Dampers
Postby Rich Oswald » Fri Feb 20, 2015 11:29 pm
Just fitted some to my S Type so that I could fit gaitors for the look and taken off adjustables. Not ridden yet, just hope theyr'e as good.
Re: Front Dampers
Postby Donnie » Sat Feb 21, 2015 11:08 pm
Indian escorts for over 10 years now and never had a problem.
Donnie
