tv175lambretta wrote:watts divided by volts gives amps. So if you've a 120watt stator and want to use it to its full potential you'll need at least 10 amp for the main power feed from it. If you're just extending a cable to a 36 watt light, obviously 3 amp will do
grumpar wrote:Hi what size and watt wire do i use to wire from the stator i need to lengthen them so just renewing cheers
Users browsing this forum: Google [Bot] and 72 guests
