Side panels
Side panels
Postby N19 » Sun Feb 08, 2015 4:21 pm
Could someone please tell me how the lip on The side panels should look. I am trying to dry fit all my panels to check for alignment and having trouble fitting them. I have new rubbers fitted and wondered should the lip be rolled over, and that fits onto the rubber. Or have mine been damaged and should have a bigger gap for them to fit over the rubber. I hope that makes sense
N19
Re: Side panels
Postby wurzel » Sun Feb 08, 2015 7:52 pm
Just had a quick look at a set of GP, SX and Series 2 panels and they all look pretty much the same.
Have you got the rubbers on the right way ( I've seen it done ) also are the side panels from that
scooter and if not have you fitted them without the rubbers first just to get an idea of the fit.
Regards Mark
wurzel
Re: Side panels
Postby N19 » Sun Feb 08, 2015 8:02 pm
Thanks Mark,
They are the original panels, and I think the rubbers are on the right way they fit on the lip well. (I've refitted them twice to be sure) I will try the panels without the rubbers and see how they sit.
Neil
N19
Re: Side panels
Postby grumpar » Sun Feb 08, 2015 8:54 pm
wurzel wrote:Just had a quick look at a set of GP, SX and Series 2 panels and they all look pretty much the same.
Regards Mark
How can you put the rubbers on wrong they only fit one way :?:
I agree try without the rubbers first also you will need to fit the handles to pull them home on new rubbers
grumpar
Re: Side panels
Postby N19 » Sun Feb 08, 2015 9:54 pm
I will fit the handles tomorrow and try again. Thanks for the help
N19
Re: Side panels
Postby wurzel » Mon Feb 09, 2015 12:45 am
What I maybe should have said was are you sure the rubbers are fitted completely over the frame lip and aren't
riding up and stopping the side panels from sitting into the groove of the frame correctly :roll:
wurzel
Re: Side panels
Postby Paul Slack » Mon Feb 09, 2015 4:21 pm
Some rubbers, especially the cheaper indian ones are very thick and make a huge difference to panel fit.
Make sure you have good quality, well made rubbers to help.
Paul Slack
Re: Side panels
Postby grumpar » Mon Feb 09, 2015 8:31 pm
Put the rubbers in warm water before fitting then give them a brush with soapy water before fitting the side panels with the handles fitted and leave overnight.
also make sure you have the frame clip-on rubbers fitted these can also make quite a difference.
If you've had the panels blasted or if they are pitted just give the rolled edge a rub with fine sand paper then all you should need to do is a bit of fine tuning on the edge i use a nylon headed hammer (with care) :D
grumpar
Re: Side panels
Postby wurzel » Mon Feb 09, 2015 9:28 pm
I've used Tutto rubbers the last couple of times and found them to be excellent quality,
didn't have to loosen them at all, just fitted them dry and they are a cracking fit and look
really well too.
wurzel
Re: Side panels
Postby N19 » Wed Feb 11, 2015 2:48 pm
Thanks for all the suggestions. I have tried again this morning, fitting the panel handles and after a few goes on and off they are fitting much better now. Maybe it was just tight on the rubbers and they will wear easier with time.
Next question, I fitted the rear panel frame clip. I have been following a blog (lambrettarestorations.blogspot.co.uk) and it shows a small tab that the clip fits under. I do not have this tab, so when I fit the panels the clip moves, because it isn't held in place. Is this right?
N19
Re: Side panels
Postby HxPaul » Wed Feb 11, 2015 4:20 pm
A lot leave the tab off,or if one is fitted bend it out of the way.It makes changing the back wheel easier,you just push the panel spring down out of the way so the wheel wil come out easier
Re: Side panels
Postby Paul Slack » Wed Feb 11, 2015 4:25 pm
The rear panels clip will be held in place once the panels are fitted. It's fine.
Paul Slack
Re: Side panels
Postby N19 » Wed Feb 11, 2015 6:32 pm
Cheers!
N19
Re: Side panels
Postby GP240 » Wed Feb 11, 2015 9:16 pm
and bang yer nuts on the flap, :D haha had to say it sorry,
looks like a nice resto N19. any more pics ?
GP240
Re: Side panels
Postby N19 » Wed Feb 11, 2015 10:43 pm
I was waiting for someone to spot that! I am waiting for the bushes before I fit the mud flap properly, hopefully should be here this week. I was going to start a new post detailing some more of the rebuild
N19
Re: Side panels
Postby Paul Slack » Thu Feb 12, 2015 1:43 pm
Please keep us updated on your build. Perhaps in show your ride section?
Glad you found my blog useful.
Paul
Paul Slack
Users browsing this forum: Bing [Bot] and 13 guests
