Spanish S2 Rear footboard with Franspeed Problem
Postby bert one » Fri Jan 30, 2015 11:52 pm
Unless I'm missing something, I cannot seem to fit the mag side rear runner without cutting most of the lower concave piece off, as it won't sit between the flywheel cowl & the Franny downpipe. The pipe sweeps quite high & you could just about get a Rizzla paper between it & the cowl. Anyone had a similar issue?
bert one
Re: Spanish S2 Rear footboard with Franspeed Problem
Postby Toddy » Sat Jan 31, 2015 9:45 pm
Which model franspeed is it ?
Postby rossclark » Sun Feb 01, 2015 1:25 am
Isn't there a specific one for wide style?
Worth a call to Andy, he's usually very helpful.
Postby Toddy » Sun Feb 01, 2015 10:01 am
Yes he does a series 2 super tourer I have just fitted one , good fit but still had to trim the end of the rear foot board
Postby bert one » Sun Feb 01, 2015 11:17 am
Toddy It's the Franny Tourer/road. BTW It's not the kickstart side, I've already trimmed that down as per usual, it's the mag side. All last year I was running without rear runners & the Avanti performs really well with this pipe. I guess it's a case of continue without the boards, cut 'em both down, or change the pipe. Does your Super Tourer allow you to fit yours?
bert one
Postby Toddy » Sun Feb 01, 2015 11:23 am
bert one wrote:Toddy It's the Franny Tourer/road. BTW It's not the kickstart side, I've already trimmed that down as per usual, it's the mag side. All last year I was running without rear runners & the Avanti performs really well with this pipe. I guess it's a case of continue without the boards, cut 'em both down, or change the pipe. Does your Super Tourer allow you to fit yours?
Yes it's fine on the mag side. With good clearance bit better than a jl3 I had on my gp that was tight like yours only on the mag though not on the footboard , i thought that had been improved on the franny though ?
Users browsing this forum: Baidu [Spider], Google [Bot] and 72 guests
