by grumpar » Sat Jan 31, 2015 2:09 pm
Hi i am having trouble wiring a ignition switch . I am trying to wire to a li type switch (with side lights on the switch) i am taking it that purple is the feed for yellow and black (side and back light) on position 2 and brown is a feed for orange (main lights) on position 3.
What i would like to do if possible is to still use the original switch as well as the key positions on the lock
I know the switch is designed to work through the sx type switch with no side light switch on the handlebars
grumpar
by HxPaul » Sat Jan 31, 2015 3:50 pm
Hi.I've just done the same thing on a series 2 Li 125.I did away with the cut out button and fit an ignition switch instead,but I wanted to use original handlebar switch,so I followed the wiring diagram in the back of Sticky's manual but instead of using an SX/GP type handlebar switch I used the original one just for dip,mainbeam and horn.
Paul
by grumpar » Sat Jan 31, 2015 6:32 pm
HxPaul wrote:Hi.I've just done the same thing on a series 2 Li 125.I did away with the cut out button and fit an ignition switch instead,but I wanted to use original handlebar switch,so I followed the wiring diagram in the back of Sticky's manual but instead of using an SX/GP type handlebar switch I used the original one just for dip,mainbeam and horn.
Paul
cheers paul i am trying to use the dip switch as well
grumpar
