by St George » Wed Jan 28, 2015 4:11 pm
The threads on the headset, top and bottom are knackered. They need complete new lugs welding on and new headlight screw threads tapped in for a new headlight rim from CASA. Question. I am in SE Essex, who knows there way around scooters that could do this local and how much am I looking at. Don't mind delivering to a LCGB member that is capable of this task. OR would it be cheaper to buy a good one, or has a member got a good one for less than ebay prices.
Cheers.
St George
by coaster » Wed Jan 28, 2015 5:13 pm
Have the lugs broken off completely? if not, they can be drilled out and the body of an ally pop rivet epoxied in prior to drilling and tapping back to original size. Welding could well cause distortion if not done vary carefully
by St George » Wed Jan 28, 2015 5:52 pm
Coaster, thanks mate, all lugs GONE
St George
by monument7 » Thu Jan 29, 2015 1:12 pm
St George
If you find a better one i'll buy the damaged one from you.
monument7
by Cgt75b » Thu Jan 29, 2015 2:13 pm
Get the original one repaired, you know it makes sense !
by Scooter Paul » Fri Jan 30, 2015 8:07 pm
Mike Phoenix can repair these, horn casts etc.
Scooter Paul
by TS1-200 » Sun Feb 01, 2015 9:04 pm
The method coaster suggests works well, just make sure that you put the ally pop rivet through from the back, from memory its a 4mm pop rivet, no good though if the lugs are actually missing
TS1-200
Users browsing this forum: Baidu [Spider], Google [Bot] and 64 guests
