911hillclimber wrote:... clutch tomorrow.My new springs (that came with the clutch kit) are 8mm longer than the thicker wire springs that came out (I think the original clutch), but I think the spring rate of the longer ones compressed is about the same as the original ones compressed to the same height. Still tempted to put the old ones back in!
911hillclimber wrote:First 'set-back' today.
Bit arrived from a new supplier in a record 18 hours via Royal Mail!
Parts of good quality, so they will be getting all my other orders.
The set-back was giving a 'professional' blasting company my engine outer cover for vapour blasting.
£5 later I have a very grit blasted cover with grease build-up still in the inside webs...![]()
What a shame and I should have trusted my first sense to leave it well alone as I did the engine block.
So, stripped the kick start mechanism down, washed all the fine grit out of everywhere (twice) and a final wet blast with carb cleaner and a good air line blast too.
You live and learn.
Second trip was I've lost the kick start shaft outer shim...
So, having been along this route today, clutch tomorrow.
Been convincing the wife the next financial lump is about now. (powder paint)
Users browsing this forum: Baidu [Spider] and 94 guests
